ticking sound
Old Nov 5, 2002 | 12:31 AM
91-GasGuzlinZ-28's Avatar
ticking sound
My brothers lebaron is making a ticking sound. The sound isn't extremely loud just enough to hear it. When you accelerate the car, the noise gets a little louder speeds up. I can't figure it out can anyone please help me?
Old Nov 5, 2002 | 12:33 AM
rezinn's Avatar
A ticking sound is typical of an exhaust leak, as is speeding up with acceleration. Drive the car in an alley or near a wall and if the sound is much more noticable, that's probably what's wrong.
Old Nov 5, 2002 | 07:54 AM
TBI305Camaro's Avatar
I second the exhaust leak.
Old Nov 5, 2002 | 08:37 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Another vote for the exhaust leak.
Old Nov 5, 2002 | 12:32 PM
SHAGME's Avatar
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
sticky valve ,mabey I dont know why no one ever thinks it could be that onthis board. has itgotten any loader just stated or what? worse when its cold?
Old Nov 5, 2002 | 12:57 PM
Morley's Avatar
Collapsed lifter, if it isn't an ohc engine.
Old Nov 5, 2002 | 06:58 PM
ohohblita's Avatar
tick, tick, tick. get out its about to blow!!!!
Old Nov 5, 2002 | 07:06 PM
Car: 99 Formula
Axle/Gears: 342
You're right, but I believe it would be more common for an exhaust leak.
Heck, it could be other reasons too, collapsed lifter, injectors.
Old Nov 5, 2002 | 10:04 PM
SHAGME's Avatar
Car: 1988 IROC-Z
srry my point is if he doesnt know anything(no offense to u I dont know u) then one reason wouldnt be good enough thnks
Old Nov 5, 2002 | 11:41 PM
pardonme2711's Avatar
stuck lifter, collapsed lifter. i had the same problem i dont know if there is ne merit to this but i was told to try to keep changeing my oil there is a minute possibilty it could free up. If not then your **** out of luck you then are better off doing a top end rebuild rather then just replaceing the lifter. Hopefully its just an exhaust leak.
Old Nov 6, 2002 | 01:50 AM
Thanks for your responses, I too think it's an exhaust leak.
Old Nov 6, 2002 | 02:07 PM
Knight350's Avatar
My 91 gta is doing the exact same thing, Mark's right, most likely it is an exhaust leak, especially if it gets louder with acceleration...
Fredel
Old Nov 6, 2002 | 06:45 PM
biff85ta's Avatar
Car: 04 Vette
Check the oil first then check for an exhaust leak if thats not the problem and it is indeed a lifter ticking try putting a small amount of trans fluid in thel oil like a half a quart or less and running the engine for an hour or so and then changing the oil this can sometimes help to free a sticky lifter.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
