Can I run synthetic oil on this engine?
Car: 89 IROC-Z
Engine: 383
I am going to probably hit 3,000 miles on my new engine this weekend and will be changing the oil. I was originally planning on changing over to synthetic at this time, however I'm not sure now.
I have read that synthetic is no good for rebuilds? Would that include a nice tight motor that was bored out and has all new parts, or simply something that was honed/re-ringed?
Also I'm not sure but I think I have a small oil leak at the rear main seal, would it become much worse with the "thinner" synthetic oil?
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
The only time you don't wanna use synthetic is during the time the rings seat and the cam lobes break in a little.
Use synthetic. It's ready.
AJ
AJ
Transmission: 4L80E/4L80E
Re: Can I run synthetic oil on this engine?
Originally posted by Paul Riccioli Jr I'm not sure but I think I have a small oil leak at the rear main seal, would it become much worse with the "thinner" synthetic oil?
Mobil 1 has a reputation for leaking and consuming more than AMSOIL. Otherwise, whether to fix the leak is up to you. Unless installed improperly and it's mechanically getting worse, the leak won't get worse on a fresh engine just because you switched to synthetic.
