Tpi No Inj Pulse
I read you similar post on the TPI board. Unfortunately, I misunderstood the symptoms. I was under the impression that the service injectors were firing but not the cold start. It seems I may have had that backward.
Am I now correct in assuming that you are getting no pulses to the service injectors?
I also understand that you have 12VDC at both injector harnesses, so that would eliminate the INJ1 and INJ2 fuses as possibilities. Since the ECM provide a ground path for each bank/harness, a reliable ground at the engine is crucial. There are a few ground wires attached to the rear of the right head. Make sure those grounds are clean and tight.
If so, the ECM will ground each bank of the injector sets once every revolution, or every four distributor reference pulses. The ECM needs to have a reliable distributor reference signal from the HEI switching module, so you might want to check the connectors at the distributor. If the circuit is good, make sure the ECM has a reliable case ground.
Incidentally, are you testing with an injector tester or scope?
Time for a ground check. The ECM pulses the injectors by switching ground, so whip out your wiring diagram and start probing.
I'd begin with the grounds at the rear of each cylinder head, and verify the ground strap from the rear of the pass side head to the firewall.
I was going to suggest the ignition module too, but I think the computer needs to recieve some reference pulses to fire the cold start injector. A bad pickup coil could make similar problems, but again I'm unsure if the cold start injector would fire.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I think it's the ignition module too. I had the same problem and I replaced my ignition module and it fired right up.
Car: 1991 Firebird
Engine: 383 stroker
First thing I would do from here is check for spark and if you're getting spark...it's not the ignition module..and if you don't get spark..change your ignition module and don't even bother having it tested. Like stated before, it's a very unreliable test.
Sanjay
Aug 12, 2015 03:41 PM
