Interpreting vacuum gauge>
Old Nov 10, 2002 | 08:13 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
I was using a vacuum gauge to set my idle a few days ago and got a reading that the books tell me is worn vavle guides. The needle bounces rapidly from about 6-10" at about 1000 rpm. If I bring up the throttle the needle steadies. I have a rough idle and I do go through oil fairly fast (no external leaks). But I don't have ANY smoke at start up (or at any other time for that matter), and never have (motor only has about 1500 miles or less on it). I haven't checked the plugs yet but I will soon. When I built the engine I had it decked so the pushrods are alittle long. I wouldn't think it would waste my guides this fast, but what do I know? Is there any possibility that this could be from my idle not being right and not valve guides? The thought of pulling the heads and having that done isn't very appealing right now.
Old Nov 10, 2002 | 11:10 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Would a vacuum leak cause this reading? That would also explain my rough idle. Much better thought than bad guides. Ideas?
Old Nov 10, 2002 | 11:25 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
if your running a lumpy cam then i wouldnt sweat it. Lots of lift + duration = low irregular vacuum.
Old Nov 10, 2002 | 11:38 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
I have the LT4 Hot camin my 383. 218*/228* dur at .050 lift and 112 sep. .525 lift. Is that lumpy enough to cause that?
Old Nov 10, 2002 | 11:54 PM
Car: 88 Camaro SC
Engine: SFI'd 350
yeah... that would cause a nice lumpy idle.
Old Nov 11, 2002 | 12:05 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Wow that's a relief. I figured I'd get alittle bumpy idle but the vacuum gauge scared me some. Thanks again.
Old Nov 11, 2002 | 03:49 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The needle can also bounce if you have a dual plane manifold and the idle mixtures aren't the same on each side.
Old Nov 11, 2002 | 09:05 AM
Vader's Avatar
...Or if you have sticky valve or bad PCV valve... I'm running a .510/.520 cam on one of the LT1s, and idle vacuum is a little low but rock steady.
Old Nov 12, 2002 | 03:21 PM
Guest
Guest
Posts: n/a
6-10 is too low for that engine. It may need some adjustments at idle, from fuel to timing to idle speed. I have a bigger cam than that and pulling a solid 12 at idle.
Old Nov 13, 2002 | 08:03 AM
Vader's Avatar
Max,
I probably interpreted his post differently. I thought it indicated that the reading was swaying from 6-10" Hg, not reading at that level (i.e., about 18" Hg but swaying 6-10).
Now, I'm not sure.
Old Nov 13, 2002 | 09:08 AM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
It is reading between 6-10" in gear (about 650 rpm not 1000 like I said at first, sorry). In park it will steady at 15" at about 1000 rpm. I am at 4000 ft elevation if that makes any difference.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
