Weight of stock rods vs eagle H beam
Old Nov 11, 2002 | 03:51 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I want to switch out the stock chevy 5.7 rods on my 383 with some eagle ones that weigh ~650grams.
The assembly was spin balanced last year and I am hoping to avoid rebalancing it? Is that weight close enough to stock or would be with maybe a little grinding to avoid rebalancing?
Old Nov 11, 2002 | 04:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not worth trying.
You're spending $350 on a set of rods, a couple more Bens on tear-down and build-up, however much time and effort in your labor, and you're going to save.... what.... $75 on balancing??? Bad idea. Baa-aa-aa-aa-dddd.
Old Nov 11, 2002 | 04:08 PM
Aaron91RS's Avatar
Car: RS
try $260 on balancing
Old Nov 11, 2002 | 04:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
worth every penny
The absolute only way I would even try it is if I had the balance card from the previous build, and a scale of adequate precision, and I could duplicate the old big-end and small-end weights exactly. It's the wrong place to try to save pennies... kind of like valve springs or rod bolts.
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
