carfax
Old Nov 12, 2002 | 02:16 AM
racereddy20's Avatar
carfax
anyone need one done? I'm carfax for the next 30 days....
Old Nov 12, 2002 | 02:37 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
sure can u run this vin
(VIN image removed by Vader)
Old Nov 12, 2002 | 02:43 AM
here you go...
GOOD NEWS! CARFAX search results confirm this 1992 CHEVROLET CAMARO Z28 (EDIT: VIN removed by Vader) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
SECTION: SECTION RESULTS:
Vehicle Specifications (EDIT: VIN removed by Vader)
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registration
Vehicle History Details 4 Total Vehicle History Records Found
NOTE: This vehicle has not been inspected by CARFAX and it may have problems that have not been reported to CARFAX. CARFAX recommends a vehicle inspection by a professional mechanic.
How did CARFAX analyze this vehicle's history?
VIN: (EDIT: VIN removed by Vader)
Year/Make/Model: 1992 CHEVROLET CAMARO Z28
Body Style: COUPE
Engine: 5.0L V8 TPI HO OHV
Fuel: GASOLINE
Driveline: REAR WHEEL DRIVE
Carburetion: FUEL INJECTED
Cylinders: 8
Manufactured in: UNITED STATES
GOOD NEWS! CARFAX search results confirm this 1992 CHEVROLET CAMARO Z28 ((EDIT: VIN removed by Vader)qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete CARFAX Glossary.
GOOD NEWS! CARFAX search results on this 1992 CHEVROLET CAMARO Z28 (EDIT: VIN removed by Vader)) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
No Reported Odometer Readings
GOOD NEWS! CARFAX search results on this 1992 CHEVROLET CAMARO Z28 (EDIT: VIN removed by Vader) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
CARFAX search results on this 1992 CHEVROLET CAMARO Z28 (EDIT: VIN removed by Vader) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
With the new CARFAX Test Drive ReviewTM, you can share your experience with this vehicle right on the CARFAX Vehicle History Report. Add to this vehicle's history here!
The CARFAX database contains a total of 4 vehicle history records on this 1992 CHEVROLET CAMARO Z28 ((EDIT: VIN removed by Vader)):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
11/04/1999 Ontario
Ministry of Transportation
Central Ontario
Ownership transfer reported
02/25/2001 Ontario
Central Ontario
Registration issued
07/06/2002 Ontario
Greater Toronto Area
07/19/2002 Ontario
Registration issued
11/12/2002 Consumer resource provided by:
Edmunds.com Manufacturer-Recommended Maintenance Schedules
Check this vehicle's service schedules, estimated costs and recall notices at Edmunds.com.
-Pete
Old Nov 12, 2002 | 03:00 AM
kool.
i was just curious... lol... i already knew all that though...
thanks tho
Old Nov 12, 2002 | 03:03 AM
if you're bored run borlaz06's too! hehehe
his vin is (EDIT out VIN by Vader)
Old Nov 12, 2002 | 09:46 AM
GOOD NEWS! CARFAX search results confirm this 1992 CHEVROLET CAMARO Z28 ((EDIT: VIN removed by Vader)) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Vehicle History Details 11 Total Vehicle History Records Found
Body Style: COUPE
Fuel: GASOLINE
Cylinders: 8
GOOD NEWS! CARFAX search results confirm this 1992 CHEVROLET CAMARO Z28 (EDIT: VIN removed by Vader) qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
GOOD NEWS! CARFAX search results on this 1992 CHEVROLET CAMARO Z28 (EDIT: VIN removed by Vader) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
03/07/1996 31,819
02/23/1998 96,790
03/07/2000 114,585
01/04/2001 119,077
01/12/2001 118,958 Reported on 12/30/2000
05/06/2002 135,834
GOOD NEWS! CARFAX search results on this 1992 CHEVROLET CAMARO Z28 ((EDIT: VIN removed by Vader)) did not uncover any of the following problems:
The CARFAX database contains a total of 11 vehicle history records on this 1992 CHEVROLET CAMARO Z28 ((EDIT: VIN removed by Vader):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
05/18/1992 California
Motor Vehicle Dept.
Title issued
03/07/1996 31,819 California
Inspection Station
Maricopa, CA
Passed emissions inspection
02/23/1998 96,790 California
Inspection Station
03/07/2000 114,585 California
Inspection Station
Stockton, CA
03/07/2000 Vehicle Repair Center
Stockton, CA
Vehicle serviced
03/29/2000 California
Motor Vehicle Dept.
Pleasant Hill, CA
Title issued
01/04/2001 119,077 California
Inspection Station
Los Altos, CA
01/04/2001 Vehicle Repair Center
Los Altos, CA
Vehicle serviced
01/12/2001 118,958 California
Motor Vehicle Dept.
San Jose, CA
Title issued
Odometer reading recorded on 12/30/2000
05/06/2002 135,834 California
Inspection Station
Los Altos, CA
05/06/2002 Vehicle Repair Center
Los Altos, CA
Vehicle serviced
Old Nov 12, 2002 | 12:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
hehehe.. this aught to be good. mine looks like it was pushed over a cliff.
edit:
No... but seriously one would help. Id really like to know what this thing has been through.
Old Nov 12, 2002 | 02:34 PM
88irock's Avatar
CARFAX help with this one please...
Thanks A LOT!!
Old Nov 12, 2002 | 07:11 PM
BORLAZ06's Avatar
I got scared thinkin something might have happened in the past. Thanks for the carfax report.
Old Nov 12, 2002 | 07:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I could use one for my 90 Stang, I'll PM you the VIN # tomorrow.
Old Nov 12, 2002 | 09:31 PM
Thanks A LOT!!
GOOD NEWS! CARFAX search results confirm this 1988 CHEVROLET CAMARO ((EDIT: VIN removed by Vader)) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Vehicle History Details 5 Total Vehicle History Records Found
Year/Make/Model: 1988 CHEVROLET CAMARO
Body Style: COUPE
Engine: 5.0L V8 TBI OHV 16V
Fuel: GASOLINE
Cylinders: 8
GOOD NEWS! CARFAX search results on this 1988 CHEVROLET CAMARO ((EDIT: VIN removed by Vader)) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
08/16/1993 28,870
12/02/1998 82,000
06/08/2000 112,001
01/07/2002 187,525
GOOD NEWS! CARFAX search results on this 1988 CHEVROLET CAMARO ((EDIT: VIN removed by Vader)) did not uncover any of the following problems:
CARFAX search results on this 1988 CHEVROLET CAMARO ((EDIT: VIN removed by Vader)) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
The CARFAX database contains a total of 5 vehicle history records on this 1988 CHEVROLET CAMARO ((EDIT: VIN removed by Vader)):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
08/16/1993 28,870 Pennsylvania
Motor Vehicle Dept.
Havertown, PA
Title #*
Title or registration issued
12/02/1998 82,000 Pennsylvania
Motor Vehicle Dept.
Havertown, PA
Title #* 03 PE
06/08/2000 112,001 Pennsylvania
Motor Vehicle Dept.
Upper Darby, PA
Title #* 04 WI
01/07/2002 187,525 New Jersey
Motor Vehicle Dept.
Moorestown, NJ
Title #*
Title issued
01/07/2002 New Jersey
Motor Vehicle Dept.
Moorestown, NJ
Title #*
Title issued
Old Nov 12, 2002 | 09:48 PM
Car: 88 Camaro SC
Engine: SFI'd 350
thanx. I guess the accident wasnt severe enough to total the car.
Old Nov 12, 2002 | 10:29 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
PM sent to you
Old Nov 12, 2002 | 10:48 PM
Tongi's Avatar
Car: '84 Trans Am Recaro Edition
Engine: L69 305 H.O.
Transmission: 700-R4
If you can run the VIN below i'll be glad.Thanks.
Old Nov 13, 2002 | 12:00 PM
Steve89GTA's Avatar
CARFAX
Can you run the following VIN?
Thanks!
Old Nov 13, 2002 | 08:44 PM
GOOD NEWS! CARFAX search results confirm this 1984 PONTIAC FIREBIRD TRANS AM (1G2AW87G1EN225062) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Vehicle History Details One Vehicle History Record Found
Year/Make/Model: 1984 PONTIAC FIREBIRD TRANS AM
Body Style: HATCHBACK 2 DR
Engine: 5.0L V8 4BBL
Fuel: GASOLINE
Carburetion: 4 BARREL CARBURETOR
Cylinders: 8
GOOD NEWS! CARFAX search results confirm this 1984 PONTIAC FIREBIRD TRANS AM ((EDIT: VIN removed by Vader)) qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
GOOD NEWS! CARFAX search results on this 1984 PONTIAC FIREBIRD TRANS AM ((EDIT: VIN removed by Vader)) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
GOOD NEWS! CARFAX search results on this 1984 PONTIAC FIREBIRD TRANS AM ((EDIT: VIN removed by Vader)) did not uncover any of the following problems:
CARFAX search results on this 1984 PONTIAC FIREBIRD TRANS AM ((EDIT: VIN removed by Vader)) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
The CARFAX database contains the following vehicle history record on this 1984 PONTIAC FIREBIRD TRANS AM ((EDIT: VIN removed by Vader)):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
11/29/2000 Ontario
Central Ontario
Re: CARFAX
Thanks!
GOOD NEWS! CARFAX search results confirm this 1989 PONTIAC FIREBIRD TRANS AM/GTA ((EDIT: VIN removed by Vader)) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
Year/Make/Model: 1989 PONTIAC FIREBIRD TRANS AM/GTA
Engine: 5.0L V8 TBI/FI
Fuel: GASOLINE
Cylinders: 8
GOOD NEWS! CARFAX search results confirm this 1989 PONTIAC FIREBIRD TRANS AM/GTA ((EDIT: VIN removed by Vader)) qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
GOOD NEWS! CARFAX search results on this 1989 PONTIAC FIREBIRD TRANS AM/GTA ((EDIT: VIN removed by Vader)) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
GOOD NEWS! CARFAX search results on this 1989 PONTIAC FIREBIRD TRANS AM/GTA ((EDIT: VIN removed by Vader)) did not uncover any of the following problems:
CARFAX search results on this 1989 PONTIAC FIREBIRD TRANS AM/GTA ((EDIT: VIN removed by Vader)) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
The CARFAX database contains the following vehicle history record on this 1989 PONTIAC FIREBIRD TRANS AM/GTA ((EDIT: VIN removed by Vader)):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
09/21/1998 Ontario
Old Nov 13, 2002 | 09:31 PM
Tongi's Avatar
Thanks for the info.
Old Nov 13, 2002 | 10:22 PM
Steve89GTA's Avatar
Thanks dude!
Old Nov 13, 2002 | 11:26 PM
SkyWarrior's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 LG4
Transmission: Borg Warner 5 Speed
Hey man, thats really cool of you to do this for everyone. Could you run these for me?
and
and
Thank you I would really appreciate it. If you only want to do one of them please let it be the first one. To make it easier for you, you can just e-mail them to me if you want.
skywarrior@excite.com
:hail: :hail: :hail:
Old Nov 14, 2002 | 03:17 AM
carfax
(EDITED OUT VIN by Vader)
you've got mail.
Old Nov 14, 2002 | 03:19 AM
no problem to all who needed the carfax. I bought the unlimited carfax reports for 30 days and I have no problem running them for you guys.
Old Nov 14, 2002 | 10:35 AM
Tongi's Avatar
How this carfax works?Are they keeping track of all the owners or is it between certain time period.Like last 10 years or something.If that's not the case can i say that i'm the third owner of the car?There's only one transfer record of my car.
Old Nov 14, 2002 | 10:38 AM
Vader's Avatar
Sorry, but I think this is going to be a dead issue on the boards due to potential liability. You might have to use email to get this done.
Incidentally, it isn't a really good idea to broadcast your VIN all over the world. Others can use it for less-than honorable purposes. I've gone back through the thread and removed the VIN and title information (numbers) for protection against this.
I apologize in advance if that annoys anyone. I absolutely HATE to edit anyone's posts, simply because it is too much censorship. I won't hesitate if someone uses inappropriate or offensive language, since they're just asking for it and violating their agreement to accept the board's terms. However, I'd much rather just delete a post than edit it. To me, changing or misquoting someone's words is a violation of their rights, so I hope you can understand my dillemma. I guess I'm just too fond of the first Amendment to the Constitution. Too bad, shoot me. (See: Second Amendment) If everyone can agree to protect themselves and not broadcast their personal information (like VINs and title munbers) I won't edit them. I didn't ask for, nor never wanted to be a "Big Brother" on the board, and I'm not changing my position now.
As for the exchange of CarFax information, I think there may be forthcoming rules regarding that.
Need details?
https://www.thirdgen.org/techbb2/ann...?s=&forumid=14
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
david068513
Sep 18, 2015 10:36 AM
Blkdth87
Sep 16, 2015 01:40 PM
dwish8990
Oct 10, 2009 11:43 AM
