Starting on the engine rebuildin'
Old Nov 15, 2002 | 02:38 AM
Enkil's Avatar
I'm going to have my engine bored and stroked to a 383. In the process, I'll be putting forged parts (crank, rods and pistons) into the engine. Since I haven't shopped around for parts like that before, can anybody reccomend a good brand? Price isn't that much of an issue, but if I can find good quality for less, then of course I'd rather get that.
Also, how long does it take to bore and stroke an engine?
Old Nov 15, 2002 | 07:08 AM
1986redbird's Avatar
if the engine you want to work on is the one in the sig. then you cant get a 383 out of that. you need to start with a 350 then bore (+.030) and stroke (3.75") to get the 383, if you've never done this kind of work before I would recommend buying a already built 383 or have a speed shop build one for you.
Old Nov 15, 2002 | 07:09 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Get the complete rotating assembley from Hardcore Racing outta Summit p/n HCR-216-86005 for $1795, then add the new trick flow top end combo Summi p/n TFS-K314-500-450 for $1729.95, Edelbrock Victor Jr. manifold EDL-2975 for $178.95 and there's your badass long block. Stick on a big nasty carb cause it's gonna be puttin out over 500hp on pump gas and you'll have to feed it, some good spark and a beefy drivetrain, then hold on
Old Nov 15, 2002 | 07:31 AM
ede's Avatar
ede
since money isn't an object look at lunati for a complete rotating assembly, ohio crankshaft and callies both make good cranks. pistions i'd look at c&a or j&e. rods i'd stick with lunati or eagle. take about hour or so to bore 8 holes and for stroke all you have to do is lay the jack down or cut a check.
Old Nov 15, 2002 | 11:43 AM
Enkil's Avatar
Oh don't worry red, this isn't for the 305. (Though, that'd be one hell of a boring job.) I've got a 350 in the 'vette that I've decided needs a little more umph to it. The IROC can stay the sensible vehicle for now. hehe
Frozer!!!
Jan 19, 2024 04:55 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
