Roller Rockers????
Old Nov 17, 2002 | 01:50 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
Roller Rockers????
I want to put roller tip rockers on my 86 Trans Am, 305-4barrel...The Rockers i have on it are factory 1.5 ratio, i want to put 1.6 ratio roller rockers on, do i have to change anything else on my motor in order to put the 1.6's on it?
Old Nov 17, 2002 | 01:52 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll need SA rr's and they won't be cheap. You'd be much better off changing the weak cam in the LG4 than replacing the rockers.
You could prolly do a cam swap for cheaper than SA RRs, I think...
Old Nov 17, 2002 | 02:12 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
I'm gonna got with the post ***** on this one. The 1.6 rockers want make a big enough difference on your 305 to justify the cost of them. If you still want to do it, most stock heads need the pushrod holes elongated to run 1.6 rockers.
Old Nov 17, 2002 | 02:22 PM
Engine: LG4 305
well, I'm getting these roller rockers for free, my friend bought them for his olds and they are for a chevy engine....elongated?????
Old Nov 17, 2002 | 02:39 PM
ede's Avatar
ede
if you have SA rockers make sure you replace them with SA or you'll have problems
Old Nov 17, 2002 | 02:41 PM
Engine: LG4 305
What is SA ROCKERS????
Old Nov 17, 2002 | 02:42 PM
Car: 99 Formula
Axle/Gears: 342
self aligning, I'd bet those ones you're getting aren't SA. look on the underside that contacts the spring, there should be a sort of lip, that kind of holds the rocker from sliding off.
Old Nov 17, 2002 | 02:45 PM
Engine: LG4 305
Thanks for the info
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Elongate as in drilling out the push rod hole so that the push rod does not rub against the head. You have to do this on some stock heads when switchung to 1.6 rockers.
Old Nov 17, 2002 | 02:47 PM
Car: 99 Formula
Axle/Gears: 342
umm, I thought the defination of elongate is to make longer, as sometimes you'll need a longer pushrod.
drilling out the hole, that wouldn't be elongating would it?
Old Nov 17, 2002 | 02:52 PM
Engine: LG4 305
So if i put 1.6 roller rockers i will need longer push rods and that is it???
Old Nov 17, 2002 | 02:53 PM
Car: 99 Formula
Axle/Gears: 342
Not necessarily, you'll have to get a pushrod measurer, also, if you have stock sa rockers, and the ones you get are non sa, then you'll need screw in studs and guide plates.
Old Nov 17, 2002 | 03:00 PM
Engine: LG4 305
Old Nov 17, 2002 | 03:03 PM
ede's Avatar
ede
you enlongate the holes or slots in the head it has nothing to do with push rod length, but you may need longer than stock push rods, but you don't say you enlongated your push rods.
Old Nov 17, 2002 | 03:19 PM
Morley's Avatar
No, elongate pertains to a hole or slot, means to move one end of it further in a direction.
A pushrod you would lengthin.
And roller rockers would be good...if they're free. But if you were going to buy them they'd be a waste of money and time unless you were building an all out race engine. For street use I'd use (and do) roller tip rockers, the best of both types of rockers in 1.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
