Cam????
Old Nov 17, 2002 | 02:04 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
Cam????
What size cam should i put in my car...86 TA, 305, carb, completely factory setup.....I want power and a nice lopy sound, but not too expensive, I'm gonna use this car as a daily driver.
Old Nov 17, 2002 | 02:05 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Comp 256XE might be your best bet for a stock setup... I'm not sure how the 262XE would work. Have you thought about headers and a cat-back?
Honestly, I'd start there first, but that is a bit more money.
Old Nov 17, 2002 | 02:13 PM
Engine: LG4 305
I'm not really sure what a cat-back is and how it works.
Old Nov 17, 2002 | 02:14 PM
Car: 99 Formula
Axle/Gears: 342
It is everything of the exhaust after the catalytic converter. Includes a 3'' intermediate pipe, muffler, and most times tips.
The stock LG4 exhaust is 2.25'' I believe.
Old Nov 17, 2002 | 02:18 PM
Engine: LG4 305
I was thinking about an exaust system but i don't know what i should use....I don't have much money to sling around.
Old Nov 17, 2002 | 02:19 PM
Car: 99 Formula
Axle/Gears: 342
I like the Hooker cat-back, $200 if you can do some minor cuttin and weldin yourself, or a $260 for bolt on.
sound clip in sig. I'd get headers first though.
Old Nov 17, 2002 | 02:30 PM
Engine: LG4 305
can i just put some pipe after the cat and put a muffler on it...this would be cheaper.....if i take off the cat will it cause any problems with the o2 sensor????
Old Nov 17, 2002 | 03:32 PM
Morley's Avatar
Can't really use just a straight pipe for the cat back portion, there are twists and bends that the pipe has to follow to maintain ground and body clearances.
Removing the cat will not effect the O2 sensor, but if you have the A.I.R. pump you'll need to remove it and block off the tubes coming off the manifolds.
Old Nov 17, 2002 | 03:50 PM
Car: 99 Formula
Axle/Gears: 342
Yup, then you prolly wouldn't have mandrel bent piping either.
You could get a Pacesetter cat-back for $140 and throw any muffler you want on it, if you don't like the one it comes with.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
