I want new heads...
Old Nov 19, 2002 | 12:10 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I want new heads...
Newbie question comming...
I'm in a position now where I think I might possibly *need* new heads (not sure yet, but it's possible). If I end up being forced to buy new heads, I would like to be able to retain my stock TPI setup. What are some "good" heads to go with given that I'm not willing to switch over to a carb/buy a whole new intake (If that's even possible)?
This is on rebuilt, but otherwise stock L98 engine on an '89 IROC.
I should note that I'm not looking to be a king-of-the-mountain racer or anything--I just don't have the money for that. I certainly will welcome any performance gains that come (i.e. more HP), but this is going to be a daily driver.
Any suggestions/starting points you could give me?
Old Nov 19, 2002 | 01:32 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I just ordered a set of aluminum Pro Lightnings for $870 shipped. They were on sale though, but I talked to the guy and he'll give a group purchase discount of 3 or more sets. I think I have one other guy interested, making you the 2nd.
I assume he sells the 180cc versions too, as that is most likely what you'll want with TPI I assume.
I can get you more info if you want.
Old Nov 19, 2002 | 05:14 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i want head! sorry just playin
Old Nov 19, 2002 | 08:07 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I know a guy in Midalothian (sp?) that modifies SBC heads. That's all he does. He's been building roundy rounder motors since the 70's.
He modified my L98 heads (which he says have good potential).
He installed 2.02 1.6 stainless swirl-polished cut-stem hardened-tip valves (plus bowl hogging), 1.44" double springs, molly retainers, new keepers, screw-in studs and guide plates for $450.
He also milled the heads .005" to clean them up, drilled out the pushrod holes to make room for the new pushrods (1.6 rockers), cut down the valve guides (for the .560 lift cam) and installed positive valve stem seals.
I haven't installed them yet, but they look like they will give a nice boost in flow. Best of all, I don't have to worry abt stuff not mounting up right and they look completely stock from the outside.
Email me if you want his #.
Old Nov 19, 2002 | 09:04 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Or port and polish some 305 heads. Follow the link at the end of my sig.
Old Nov 20, 2002 | 10:00 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
check out these guys jr motorsports . they have a cast set for sbc that i got that are around 400 for the pair with springs and everything minus rockers and u can pick the valve sizes. something good to look into if you arnt going all out with this car.
trickedout02
Jan 12, 2004 11:01 PM
Chris89GTA
Feb 13, 2003 01:35 PM
Drowned
Aug 5, 2002 10:25 PM
Chrome
Aftermarket Product Review
Sep 25, 2001 09:02 PM
ColinOpseth
Jun 14, 2001 03:54 PM
