Fuel Economy ?
Old Nov 22, 2002 | 01:30 PM
Andrew85-Z28's Avatar
Fuel Economy ?
Hi Everyone,
I just bought an 1988 L98 GTA. The car has had a complete tune-up, an alignment, and the ECM shows no codes. The problem is that i'm getting 10 mpg city and 18 mpg highway WITHOUT pushing it (never sees the high side of 4000 rpm). Do you have any ideas why it takes so much gas?
TIA
Andrew
Old Nov 22, 2002 | 01:35 PM
TBI305Camaro's Avatar
have you checked the o2 sensor? Id try that if it wasnt done during the full tuneup.
Old Nov 22, 2002 | 01:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Yeah, check the o2 sensor, that's just horrible mpg.
Old Nov 22, 2002 | 01:59 PM
OH NO I CAN'T FIND MINE!!!!!! WHERE IS IT...oooooooo yeeeeah
Old Nov 22, 2002 | 02:16 PM
Thanks guys for the info. Isn't the computer supposed to throw a code for this?
Old Nov 22, 2002 | 03:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not necessarily... the computer has no way of knowing if it's just bad, as long as it sees some degree of response to its actions. Unplugging it or shorting the wire will set the code, and the reading always staying the same (no cross counts). Just being out of calibration, so to speak, won't necessarily appear as an error to the ECM.
Try replacing it. It's the most common cause of bad gas mileage.
Old Nov 22, 2002 | 04:01 PM
Thanks RB, I'll go get a new one and replace it.
Old Nov 23, 2002 | 08:22 AM
StangKiller's Avatar
I just replaced mine a few weeks ago and picked up 3-4 MPG, it was only about $18-20 at Advance for a Bosch O2 sensor.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
colton_carlson
Mar 8, 2019 12:21 PM
mike_c
Aug 27, 2015 04:32 PM
92camaroJoe
Aug 13, 2015 06:07 AM
