weird noises from the engine
Old Nov 23, 2002 | 08:49 PM
larry92rs's Avatar
I have a weird noise from the engine this noise only starts when wheather temp., drops below 50 if above 50 then the noise stops after engine has warmed up to 170 then runs quietly. this has been going on for sometime, different people looked at the car but dont know. a friend of mine also looked at it and he cant say
it doesn't effect the way the engine runs just want to know whats going on sounds like its from the balancer or crank pulley because its at the front its no inside the engine other then that has no other sounds dont leek oil or brne oil and is clean on top and bottom.
1992 rs.... all stock.... 305 TBI.
Old Nov 24, 2002 | 12:42 AM
rezinn's Avatar
Can you describe the sound? Engines can make a lot of different noises, so right now we're pretty lost in trying to help.
Old Nov 24, 2002 | 05:46 PM
larry92rs's Avatar
yes it always helps to explain the engine noise when trying tp get answers...
ok sonds like the pulleys are playin the baby rattlers, thats the weird sound it has.
the cat doesn't have a heat shield on so i know its not that and everything els that could possibly make that sound is tite or gone. again I'm sorry and thankyou for sending the email..
you guys are good becouse i 've read the things thats been posted. thank you
Old Nov 24, 2002 | 06:20 PM
Slade1's Avatar
Try getting some wd-40 into the bearings on all pulleys.
What happened to my tensioner pulley was that the bearings were starting to go so I bought a new tensioner and got a bonus that it was aluminum. So got a bit of weight savings and fixed the odd rattle.
Old Nov 24, 2002 | 06:56 PM
larry92rs's Avatar
ok thank you Ill try that
theshackle
Sep 17, 2020 08:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
B_Dubya
Aug 26, 2015 05:09 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
