Spark Plug gap vs flatter torque curve
Old Nov 25, 2002 | 07:09 PM
Slade1's Avatar
Anyone have results of the relation between spark plug gap and ability to maintain torque into the midrange rpm band.
I was thinking that provided your ignition system is up to task, a larger gap would give you better ability to ensure a good burn at midrange rpm since there is more spark essentially.
Any downsides to running larger gap?
Stock 35 to say 45?
Old Nov 25, 2002 | 08:01 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You might gain 0.002% more HP by opening up the gap, as long as it can still fire reliably.
Old Nov 25, 2002 | 08:26 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
With the HEI's the minimum gap I'd have is .045, I got a little better than stock and run mine at .060 w/ no problem. HEI's got zing and can handle the wider gap w/ no problem.
Old Nov 25, 2002 | 08:39 PM
Slade1's Avatar
It's not HP that I'm after, its keep the torque curve as flat as possible till I hit other restrictions that prevent this from being possible.
Old Nov 25, 2002 | 09:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I doubt you'd notice any difference.
Old Nov 25, 2002 | 10:10 PM
Slade1's Avatar
I'm wondering if I should go through the trouble of it because there are quite a few people now I've talked to that have re gapped theirs to say 45 or 55 and have said that their midrange improved somewhat.
I wouldn't have thought much about it till I saw a dyno result of a 45 gap tpi vs a 35 gap tpi and the curve was more noticibly flatter. The slope of the drop off after peak torque was significantly less. The ignition system was a jacob's 65000 V so I wasn't really sure though how much that comes into play or not...
Old Nov 25, 2002 | 11:24 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i doubt youll genuinly gain much if its already properly gapped. The differences would probably be too small to conclusivly see with a stock, or near stock setup.
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
