can anyone tell me whats goin on?
Old Nov 26, 2002 | 08:32 PM
87PontiacBeast's Avatar
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
every day my radiator is low of antifreeze. i have to fill it every day because its always low.. theres never any antifreeze under the car so where the hell is it all goin? from what i can see it looks like theres no leaks. i'm not a car expert so if anyone can tell me where my antifreeze is goin i would be very thankful.
Old Nov 26, 2002 | 08:53 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Oh man, I hope it isn't this but sometimes it will end up in the oil if you have a blown head gasket (which is OK because it's fixable) OR due to a cracked block or head. The last two are a real pain--you can replace a head easily enough but a cracked block is usually death to the engine
Old Nov 26, 2002 | 08:54 PM
pskel350's Avatar
in my old thunderbird, coolant was leaking back into the tranny. it really messes up the tranny. check your tranny fluid first.
Old Nov 26, 2002 | 08:59 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
would i be able to check through the oil and tranny fluid. if yes what am i lookin for?
Old Nov 26, 2002 | 09:01 PM
Engine: 305-4v
Oil will look milky.
Not sure about the tranny fluid but I assume it would do the same.
Old Nov 26, 2002 | 09:02 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
i forgot to ask this... if the block was cracked wouldnt i be able to notice it leaking onto my driveway or wherever i park? every where i park its spotless.. it doesnt leak at all.
Old Nov 26, 2002 | 09:19 PM
Engine: 305-4v
No, because the leak will be internal, like between a cooling passage and an oil passage. It won't end up on the ground but rather in the oil pan
Same with a head leak or gasket. You'd notice a bad running engine with the latter two, however.
Old Nov 26, 2002 | 09:21 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
bad running engine as in hesitation? because it hesitates alot now..
Old Nov 26, 2002 | 09:23 PM
pskel350's Avatar
the tranny fluid will look foamy, and discolored some. if it is a cracked block, it might be a smaller enough crack and in the right spot so it would only leak when the coolant system is under pressure(ie. when you are driving) so coolant might not leak out when your car is just sitting.
Old Nov 26, 2002 | 09:26 PM
Engine: 305-4v
Well, I had a head gasket let go on me in Tuscon one day. The engine started to miss like crazy and white smoke came out the tailpipe. That was the antifreeze turning to steam on the way through the combustion chamber!
But pull out your dipstick (the one in the car) and see if the oil looks like hot chocolate. If so, that's the problem.
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
i already tried testing that by filling up the radiator at night and by morning it was low again.... is there a possibility of a bad radiator cap?
Old Nov 26, 2002 | 09:28 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
lol.... i'm gunna check the fluids first thing tomorow morning
Engine: 305-4v
Yes, it could be the cap. But you would notice the engine boiling over through the reservoir if that were the case.
Old Nov 26, 2002 | 09:31 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
yea it does boil over through the reservoir! ...... i'm buyin a new cap tommorow and we'll see what happens... lol
Engine: 305-4v
If your other "oil" looks like hot chocolate, you got a problem there, too
Old Nov 26, 2002 | 09:33 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
lol :sillylol: if that was the case i wouldnt be hear right now.. i'd be in the emergency room
Engine: 305-4v
Well, that is probably the problem. Just happened to me a couple weeks ago. Only $5 for cap, thankfully
Old Nov 26, 2002 | 09:34 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
5$ for a cap beats the hell out of buyin gallons of antifreeze
Old Nov 26, 2002 | 09:35 PM
Engine: 305-4v
Beats the heck out of a new engine block, too
Old Nov 26, 2002 | 09:38 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
hell yea.. although a new engine would be nice
Old Nov 27, 2002 | 09:42 PM
Car: 92 firebird
Engine: 305 tbi
Transmission: t-5
ok i bought a new cap today but it seems like it doesnt fit on right... i looked up the part number and got the one that should fit my car but when i got home it seemed like it didnt fit right. are they suppposed to be a little loose or are they suppposed to be tight. ill find out tommorow if it worked and if my car still has antifreeze in it.
Old Nov 28, 2002 | 01:04 AM
Engine: 305-4v
Mine fit quite properly, it wasn't loose.
Old Nov 28, 2002 | 04:45 PM
Andy Bush's Avatar
When you refill the radiator on the Camaro, it does not fill the whole system. For example it does no go up into the upper hose because that is higher than the filler cap.
The rest of the filling action occurs after the engine heats up and cools down again a fw times. What happens is the air gets blown into the header tank as the engine heats up. When it cools down again the vacuum suck coolant from the header tank. This keeps happening until the cooling system is fully primed.
For this to work properly, you must have the correct radiator cap and it has to be working properly. It has two spring loaded valves in the cap. One opens to let the air and excess pressure coolant out of the radiator. Th other small one opens when the radiator pulls a vacuum and it allows coolant from the header tank into the radiator.
After a total engine rebuild, you may have to refill the coolant header tank several times before it stops going low.
This does not mean you don't have a leak, but it is the cheapest thing to fix if it is the problem. The cap should be a tight fit, and probably more than $5.
S10K20
Oct 7, 2015 06:45 PM
1982chevycamaroz28
Aftermarket Product Review
Nov 26, 2001 11:36 AM
88greyiroc
Jul 22, 2001 02:58 PM
MurphsIroc
May 31, 2001 12:20 PM
86FyrBrd
Feb 5, 2001 09:18 PM
