Would I see anything out of this cam?
Old Nov 26, 2002 | 11:48 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
This cam is out of a ZZ4 350.
Duration @ 0.050" Lift: 208/221 Lift: .474"/.510" Lobe Separation: 112 Type: Hydraulic roller tappet 5.7L HO 350
I dont know anything about this stuff, yet, and I wanted to know if this would benefit my 89 GTA 5.7 auto all stock. If this would not help out what kind of numbers should I be looking for? I need to be legal in CA.
Thanks,
Brian
Old Nov 27, 2002 | 01:04 AM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
yes. You probably wont get a SES light either, but most people will tell you that to take full advantage of the cam you should get a custom chip. On the conservative side, you'd probably get 20hp out of that cam compared to what you have in there now. Be ready to change valve springs and timing chain set with the cam.
Old Nov 27, 2002 | 02:56 AM
rezinn's Avatar
That cam is a bit much for the stock long tube runner setup. It likes to rev a bit more than you can. If you don't have headers, those are probably the #1 mod people like to do.
Old Nov 27, 2002 | 02:05 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Is there an easier way of changing cams without yanking the engine out? Does the front end come off enough to get one out and one in? Is $135 a good price for that cam or would I be better off to get another one? I have thought about a custom chip but I dont have the $$ right now to get all of the programing equipment. How much do custom chips usually run? And finally the last question, will there be a decent improvment in my exhuast sound? I have a 3" cat back on it right now as it is.
Thanks for all the help
Brian
Old Nov 27, 2002 | 02:09 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You can do an in car cam change , not that bad, though the back and knees might hurt a little at times.
You have to take the radiator out, and bend the front support bars a tad, for the cam to slide out, of course among with everything else that needs to come off normally.
Old Dec 1, 2002 | 02:04 AM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Do you have any pics of the support bars that need to be bended a tad? I am going to show my buddy what needs to be done to make sure we can do it all ok
Brian
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
masonta
Sep 1, 2015 06:40 PM
