whooooo finally the big red hunk of metal LIVES!!! WOO
after a few painful weeks of askin over and over...i wonder whats wrong....it LIVES...!@#$! wire harness on the coil was unplugged.....
o man i feel like the biggest jack ***...anyway shes still showing a code 34, but running great after all the parts ive put in lately
comon guys help me out.
joe
joe
no MAF wasnt unplugged, it was one of the wire harnesses that plug into tha coil =\ go figure.
but im still gettin a code 34= MAF or MAP sensor...how can i check if these are ok?
Car: 85 IROC
Engine: LB9
well first is your car MAF or MAP/SpeedDensity?
If its MAf I would check the connections to the MAF and the other little sensor thing (forget right now what it is) in the air ducting. Make sure they are clean and secure...reset your ECM by disconnecting the battery or pulling the ECM fuse for a few minutes, try it out.
If its MAP, locate your MAP sensor (again memory fails me where its at on a 3rdgen) make sure its got good vacuum from the manifold, follow its vacuum line back, make sure its connected to the intake and in good shape, and also make sure its electrical connection is clean and tight. reset ECM, try it out
Car: 85 IROC
Engine: LB9
oh you mean like why did some idiot leave that oil can that says bosch blocking up my intake
hehe try those things i said and then if it still chunks a code at you, come back here do a search on MAF and Code 34, I am sure you will find a lot more about testing and trouble shooting a bad MAF...people don't like to buy em, those suckers are expensive.
Polo Z03
Sep 10, 2015 06:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
