stainless steel fuel lines
Old Nov 27, 2002 | 05:26 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i have the braided fuel lines and i cant seem to make them fit into the fittings anybody know how to do it
Old Nov 28, 2002 | 12:48 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
I don't remember but I think they just fit in and use a compression type of retention... I'll ask my dad he works on jets all day
Old Nov 28, 2002 | 01:10 AM
jocww's Avatar
ok thanks cuz it seems like i cant force it in and its starting to **** me off
Old Nov 28, 2002 | 02:04 AM
dans82bird's Avatar
Engine: 302
what kind of fittings are you trying to use... what size is the hose and fittings? have any pics?
Old Nov 28, 2002 | 06:22 AM
ede's Avatar
ede
i used stainless compression fittings to adapt my aluminum line to the braided stainless. wasn't hard to find, i got aeroquip fittings from parts store that made my lines.
Old Nov 28, 2002 | 06:33 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Well youll have to tell me what kind of fittings and hose you are trying to work with.
I'm an aircraft hydraulics mechanic and I build all kinds of hoses on a daily basis. Some fittings can be a real bitch. let me know what you have.
Old Nov 29, 2002 | 03:08 AM
jocww's Avatar
fuel line from summit trying to go into-6 an 90degree swivel head fixture or fitting.
everytime i try to force it in it frays more and more
Old Nov 29, 2002 | 05:15 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Trim the end of the cable to get rid of the frayed bit. To cut it, wrap it tightly with tape and use a sharp fine hacksaw or a cut-off wheel. Peel the tape off and put a worm-type hose clamp on the end so that no more than about 1/16" is sticking out past the clamp. Tighten it down to compress the braid enough to get the fitting on once you've got it started, loosen off the clamp and slowly work the end on.
Old Nov 30, 2002 | 08:02 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Apeiron said it
usually though if its a clean cut you dont need to put anything over the braids to get the fitting on. Good idea on the hose clamp though, when I have problems with fraying I usually use a zip tie over the end (same principle).
Pablo
Old Dec 2, 2002 | 12:00 PM
jocww's Avatar
still doesnt work
Old Dec 2, 2002 | 03:14 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
AN compression fitting are always a bitch to get on....they fit really tight (thats why they do the job though)
Old Dec 3, 2002 | 12:28 AM
jocww's Avatar
what happens if i put grease
Old Dec 3, 2002 | 01:57 AM
Car: '91 Camaro RS
well ya really dont want that in the fuel line, but maybe a very small amount of a light grease would help.....however, it could make the fitting more likely to slip apart too
Old Dec 3, 2002 | 02:08 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
are you still having problems getting the sleeve over the hose braiding? tell us exactly what is giving you problems. It shouldnt be that hard unless you are doing something wrong or you have the wrong fittings.
Old Dec 3, 2002 | 04:10 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
What size fitting should go on the stock fuel lines on the frame? -6 right? thanks
Old Dec 3, 2002 | 04:14 PM
Car: '91 Camaro RS
umm its not the size of the line that makes a difference its the size of the coupling fitting that adapts it to the hard line. i cant remember what size mine were
Old Dec 3, 2002 | 06:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The stock fuel line should be 3/8" tube, so a -6 AN flare nut and sleeve works well.
Old Dec 3, 2002 | 06:27 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Sorry for the confusion 383, if you were responding to me! I thought i had asked for the size of the fittings. Thanks Apeiron, thats the size i had come across somewhere else and that was the size i was going to order. Later-Bryan
Old Dec 3, 2002 | 09:46 PM
Car: '91 Camaro RS
yep -6 flare nuts....thats what i used, works great, it leaked alot at first because i f-ed up putting it on, but i fixed it hehe
always wondered why they dont just say #6 or something, whats the deal with stupid dash
Old Dec 3, 2002 | 10:51 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
I was wondering that myself when i go to order them! I guess i'll just say, "size 6"!?!? Thanks guys-Bryan
Old Dec 4, 2002 | 12:53 AM
jocww's Avatar
umm i cant seem to get it to fit over the hose and the fitting is now all scratched so i cant return it. it seems liek the fiting is to small but it is all -6 an so i dont getit the hose is all frayed
Old Dec 4, 2002 | 11:00 AM
Vader's Avatar
...and everyone wonders why the factory used hose with a wire inner braid and rubber outer cover?? It's the same thing (or better) and doesn't hold all the dirt.
I s'pose it doesn't look cool, though... For heat resistance, there are thermal slip covers available, and they work better than bare, exposed braid.
Just my 2¢
Old Dec 4, 2002 | 11:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it's like most of those that I've had to deal with, he's having trouble getting the braid to go into the nut as he forces the hose over the barb of the fitting. A very comon difficulty.
Unfortunately there's no esy answer... a diamond-edge cut-off saw, and electrical tape on the braid before you cut it with the saw, are the only way I know to make a sure-fire connection. I've never had reliable succes with a hacksaw although sometimes I can get it to work after a couple of tries. If even one strand of the braid is bent or unraveled, it will never go together.
You might want to put a piece of tape over the end of the hose, take it back where you bought it, and have them cut ¼" or whatever off the end of the line with their cutoff saw, such that it's in the middle of your tape; and don't take the tape off until it's all the way together.
Old Dec 4, 2002 | 11:20 AM
jocww's Avatar
summit is a far away place
Old Dec 5, 2002 | 12:39 AM
jocww's Avatar
i gave it to my friends dad to figure it out he knows
Old Dec 6, 2002 | 02:23 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
if its frayed and you are forcing it, you are only going to make it worse. Youll reach a point where you will just have to make a clean recut on the line.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
