Computer facts on 305 buildup
Old Dec 1, 2002 | 01:58 AM
Firebird sweden's Avatar
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Hallo!
I am going to do some mods to my car this winter so if you will make a comments about these facts I be pleased.
Whith these mods the engine will create following specs,can that be for real.
RPM HP Ft.lbs
2000 131 343
2500 167 350
3000 205 360
3500 246 369
4000 283 371
4500 315 368
5000 333 350
5500 334 319
6000 317 277
These specs are whith vortec heads I am going for ported tpi heads.
Here are my other mods:
High flow TBI unit from cfm tech 570cfm
Edelbrock TBI performer intake
compcam extreme energy The duration at .050 is 206 on the intake,and 212 on the exhaust.It has a valve lift of .480 on the intake,and .488 on the exhaust.It has a lobe seperation angle of 112.
Hooker headders,Y-pipe
3" fullflowsystem flowmaster whith highflow cat.
custom chip
Low temp stat 180
Are there anything else I chould think of let me now.
By and thanks!
Old Dec 1, 2002 | 02:45 AM
radiateu2's Avatar
mods
B&M filter roller rockers you may wanna upgrade springs with that lift and replace the pressin rocker studs. Gasket match the intake do not polish it though. If this is a 350 your TBI unit may be challenged with your mods Port the intake runners but dont polish them. port and polish the exhaust side of the heads. Thats all I can think of right now. Good luck and have fun.
Old Dec 1, 2002 | 08:58 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's a good cam for that motor, if it's the XR258HR (12-408-8).
Those numbers are meaningless. No way that motor is going to make that kind of power once it's in a car. I doubt it would even do it on a dyno stand. With the 305 heads I'd expect something more near the 250 HP peak range at 4300 RPM, peak torque around 275 at around 3000-3200 RPM. Still, a nice improvement of almost 50% over the 170 HP you have now.
Old Dec 1, 2002 | 09:39 AM
Engine: 383 HSR TPI
Axle/Gears: 4.10
OK!
I will be pleased anyway becouse my goal was 250-270hp an still running TBI,I was just interrested if those numbers could be for real.
Thank you all!
I will be starting the last mods in January.
Jake_92RS
Jan 28, 2020 10:37 PM
fbirdroller
Sep 2, 2015 10:27 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
