Engine price question
Old Dec 1, 2002 | 08:32 PM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
ok im missing something or i just havent read over all of it right or something http://www.chevy-gas-diesel-engines....ngine-243.html y is it so cheep? whats missing from it it doesnt really tell me much just that i can get preformance parts but that might cost more any reason/ suggenstions on what kind of 350 to get need something fairly cheep 1000-1400 or so feed back much appriciated
Old Dec 1, 2002 | 08:59 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
It's remanufactured for one...
I think those are horrible heads too, can't really recall the head casting #s though so I could be wrong.
Old Dec 1, 2002 | 09:42 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Block:
14093638...350...87-95...2 or 4...Roller or flat tappet cam 1 piece rear seal
Heads:
14102191...87-up...350
14102193...87-up...305/350......1.94"/1.5" valves
The heads are, if I remeber correctly, swirl port heads which are junk. They also don't use brand name parts to rebuild thier engines. I wouldn't buy from them, you could buy a brand new GM 350 for $1500.
Old Dec 1, 2002 | 10:01 PM
Car: Camaro
Engine: 5.slow
$1500, from where would u sugest thou?
Old Dec 1, 2002 | 10:20 PM
Car: Camaro
Engine: 5.slow
ok what about this one http://www.sdpc2000.com/cart.asp?act...id=128&pid=110 ??
Old Dec 1, 2002 | 10:23 PM
kfoley's Avatar
Car: '85 Z28
Scoggin Dickey, Summit, Jegs, Your local dealership. Shop around for prices, who knows, you local GM dealer could have the cheapest price (not likely, but it could happen). Here's the link to the GM 350 at Scoggin Dickey:
Old Dec 1, 2002 | 10:25 PM
kfoley's Avatar
Car: '85 Z28
Yep, that's the one. If you wanted to get some more power out of it, you could throw in a bigger cam (stock cam is weak) and maybe port the heads some. Stock it pushes out 249hp and 304tq.
Old Dec 1, 2002 | 10:26 PM
Car: Camaro
Engine: 5.slow
lol im seeing double :lala: :lala: but yea i kinda wannted to spend alittle less but yea if thats a good engine then ill be willign to spend i will need to save alittle extra but yea ill search around just wanted to see if the guys on the board thought that the engine that i was picking showed some promise is all
Old Dec 1, 2002 | 10:31 PM
kfoley's Avatar
Car: '85 Z28
The Goodwrench 350 is a good strong engine, and it's backed by a 50k mile warranty. Better than any remanufactured engine you could get. I would reccomend it to anyone wanting a low budget 350.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
