How do i use a non-inductive timing light?
Old Dec 4, 2002 | 03:00 PM
hilljackofdenile's Avatar
Okay, i think i have a non inductive timing light. i got it at a garage sale a while ago and would like to try to use it. Im pretty sure its non inductive because the clip is just a bare metal alligator type clip. I guess its called a "series timing light"? i duno, can someone tell me how to use it?
thanx
Old Dec 4, 2002 | 03:09 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It should have a spring that the clip attaches to. You yank a plug wire and put the spring in-line between the wire & plug (or wire & cap connection).
Old Dec 4, 2002 | 04:43 PM
Jza's Avatar
Jza
You don't. Damn those things are dangerous.
Especially with a multiple spark discharge unit and high-output coil. Eghew. I can still feel it.
Spend the $20 and get an inductive light.
Old Dec 4, 2002 | 04:57 PM
cool, were can i get a $20 inductive light?
Old Dec 5, 2002 | 07:21 AM
Vader's Avatar
Oh, c'mon. Let him learn the hard way. It's more fun to watch....
Old Dec 5, 2002 | 09:10 AM
Jim85IROC's Avatar
What's so dangerous about it? 1.21 jigawatts never hurt nobody.
I've been shocked by mine more times than I can count. You get used to it after a while.
Old Dec 5, 2002 | 01:12 PM
Jza's Avatar
Jza
Wal-Mart has 'em last time I looked around there. I was of course talking about a cheapie plastic non-adjustable one. The better you get, obviously the more it costs.
What's remarkable is, the first time I figured it was because I leaned against the fender and grounded myself so I tried it again and figured out that it was the metal case of the timing light. I told Eddie where to stick his timing light but thanks anyway for letting me borrow it.
I should have bypassed the MSD unit anyway to set timing. The cheap inductive timing lights seem not to like the multiple sparks.
Old Dec 5, 2002 | 03:40 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
All you really need is a lightbulb and a piece of wire.
Old Dec 6, 2002 | 01:17 PM
actually, i was wondering, why couldnt you just hook up a flash bulb from a disposable camera either parallel or in series with the no 1 spark plug?
Old Dec 6, 2002 | 02:22 PM
Enkil's Avatar
I suppose you could, but then, since people have already made timing lights for this purpose, why would you?
Old Dec 6, 2002 | 02:25 PM
eh, just wondering, it would be a good way to electricute myself AND be cheap at the same time
Old Dec 7, 2002 | 02:37 PM
Okay, i just checked my timing with an inductive light, and its at 12* advance. I think i did it right: got the car to operating temp, pulled the ECT wire, hooked up the light to the #1 plug and fired away... Im gonna set it back to 6* when i get one of those stinking wrenches to get at the dist. bolt. But could the 12* advance be whats causing me to have a hesitation when accelerating from a standstill, or after ive let off the gas for a turn and then hit the gas after the turn?
Old Dec 7, 2002 | 03:37 PM
Bort62's Avatar
yes
Andrew6.688
Dec 13, 2015 10:59 AM
justin57
Aug 20, 2015 07:05 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
