best valve size with L98 aluminum heads??
Old Dec 5, 2002 | 06:22 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
ok guys here is the deal i am building up a 355, forged crank, rods, pistons, aluminum L98 heads, 10.5-11.0 compression, crane cam with 1.6 rockers to make the lift .498 .513, headers, 2800 stall, ported intake, adj fuel regulator, and about every free mod there is, now what size valves should i use. no matter what size i am getting manley RACEFLOW valves but still stuck on 1.94/1.50 or 2.02/1.60. i heard some where that 2.00/1.55 or something flowed the best but asking opinions dont really have the cash right now to get new valve seats but yet i am not drivng it so i could wait........ please post up
Old Dec 5, 2002 | 07:25 PM
86IROCTHD's Avatar
Car: 88 Trans Am
no help? come on guys
Old Dec 5, 2002 | 08:05 PM
19WS6T/A91's Avatar
i could be wrong(someone correct me if i am) but the 1.94/1.5 valves are stock valves. with your engine and combo you should deffinatly go with 2.02/1.6
david
Old Dec 5, 2002 | 08:28 PM
Guest
Guest
Posts: n/a
I think the reason people go with the 2.00 and 1.55 are to avoid replacing the seats. Pretty sure 1.60's work on the exhaust ok though.
Old Dec 5, 2002 | 10:59 PM
86IROCTHD's Avatar
Car: 88 Trans Am
madmax
please explain.... i wouldnt need to change the valve seats?
Old Dec 5, 2002 | 11:13 PM
89ProchargedROC's Avatar
2.00/1.55
any bigger and you run into valve shrouding problems within the chamber itself
Old Dec 5, 2002 | 11:37 PM
86IROCTHD's Avatar
Car: 88 Trans Am
ok yess but would i need new valve seats?.... i think i am gonna stay with the 1.94/1.50's if i want to go bigger i will pull them back off.... dont drive it every day so u live and learn
Old Dec 6, 2002 | 12:24 AM
Guest
Guest
Posts: n/a
There are quite a few heads with small valves that the seats are way too narrow to accomodate such a large change in valve size. I'm pretty sure you cant put 2.02's in a vette head without replacing the valve seats.
midge54
Dec 27, 2019 04:14 PM
toronto formula
Nov 10, 2015 06:17 AM
gta90
Sep 15, 2015 04:00 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
knight72
Aug 10, 2015 09:32 PM
