water pump....which one?
Old Dec 5, 2002 | 06:57 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Im changing my water pump....well going to be anyways.......Anyone have any ideas which one to go with? At least one that will fit mine with no problem.?
Old Dec 5, 2002 | 07:24 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
Stay away from stock choices in waterpumps....i have had 2 in mine that went bad so far (1992 Trans am ) i finally got a JEGS Magazine and bought me a ( Weiland water pump part # 925-8208 rev flow ) cost is $ 94.99 but its an aluminum cast waterpump which is 30-50% lighter than OEM water pump....u can get the cast iron one which is..$67.99 part #925-8250.....good luck and keep that bird flying above the rest.....here is JEGS number also........1-800345-4545 or jegs.com....
Old Dec 6, 2002 | 02:28 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Thanks alot man......really appreciate....
Old Dec 7, 2002 | 08:34 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I agree with the last post, spend a few bucks on an aftermarket aluminum like the Weiand, Edelbrock, Moroso etc - there are probably more brands.
You shave a few pounds off the front of the car that way for sure, they look better, most flow more volume (should you need it), and the impellers are designed to work well at high speed - unlike the stock stuff.
Old Dec 7, 2002 | 08:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't screw around with a bunch of wannabees, go for the real thing. Very affordable, permanent.
www.stewartcomponents.com
Old Dec 7, 2002 | 10:51 PM
TBI305Camaro's Avatar
Mine went out last summer when I had no idea about cars. I just bought a replacement from advance...brand new for like 25$. Working fine so far...keeps the 350 cool. When it goes im gonna get a good pump tho.
Old Dec 8, 2002 | 01:20 PM
gruveb's Avatar
Car: 1989 IROC-1
Ditto
Unbelievable quality......not to mention, cheaper than edelcrap and weiand!
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
jrdturbo
Mar 31, 2016 02:58 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
st.evel07
Sep 19, 2015 09:24 PM
