U wanna see the dragstrip casualty?
Old Dec 7, 2002 | 08:54 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
This happened in September at the local dragstrip about 20-30 yards from the 1/4 mile mark. It still ran a 13.7 at 90 mph. It wasn't my Camaro, thank ***, it was my S10. I just thought it would be a great reminder to be careful.
Old Dec 7, 2002 | 08:56 PM
Car: '84 Z28
here it is
Old Dec 7, 2002 | 08:59 PM
Car: '84 Z28
look at the back of the block above the bellhousing? does anyone know of the correct way to fix this. I have heard a lot of diff. methods. ( braze w/ a nickel rod, JB weld, Magnumsteel, arc weld with cast iron rods)
Rage13's Avatar
Car: 89 Firebird
that sucks, and you still ran faster then i do...
Old Dec 7, 2002 | 09:02 PM
Car: '84 Z28
there is a chunk of the block missing right above what used to be the flywheel. I still have the peice thats missing.
Old Dec 7, 2002 | 09:32 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
what exactly happened there??? you can weld the broken piece back on your block but i hear cast iron is really hard to weld, you gotta know what you're doing
Old Dec 7, 2002 | 09:41 PM
Car: '84 Z28
Not sure. Even my transmission guy was in awe. It also broke the yoke off of the rearend, flattened my exhaust tube, blew my right front tire out (flywheel teeth), punctured my gas tank, and put a baseball sized hole ih the floor board. Oh yea check out the starter and the framerail in that pic.
Old Dec 7, 2002 | 09:47 PM
Rage13's Avatar
Car: 89 Firebird
you alright? i'd going to get a trans shield for sure now.. damn, thats a big hole...
Old Dec 7, 2002 | 09:51 PM
Car: '84 Z28
Yea I'm fine but I was very lucky. I later found flywheel teeth under the carpet.
Old Dec 7, 2002 | 09:56 PM
Bort62's Avatar
I think Its pretty Obvious your Flexplate Came Apart.
What Kind of parts are we talking here... stock flexplate or what ?
What Sort of power levels ?
Your a Lucky guy, I think we all take fo granted just how fast that stuff is spinning down there somtimes.
Old Dec 7, 2002 | 10:06 PM
Car: '84 Z28
It was a stock flexplate. I'm guessin 300-350 hp not sure b/c desktop dyno is full of crap. My combo is 010 block .030 over (355) home ported 041's, screw in studs and guideplates, aluminum roller rockers, Comp XE268, 9.73 to 1 hypereutectics,weiand Xcellerator,holley 600. This engine and trans. had 19 miles on them after break in. That was the first and only run down the 1/4. No chance to tune.
Old Dec 7, 2002 | 10:21 PM
Bort62's Avatar
I bet the Ring was Cracked Prior.
Thats a rough break, Man. Its hard to tell form the pic, wich part of the block broke?
Sructural, Or just sorta "there" ?
Old Dec 8, 2002 | 12:51 PM
Vader's Avatar
If you really want to weld the engine case, I'd suggest investigating the possibility of using nickel filler. It makes a very strong alloy with iron.
Old Dec 8, 2002 | 02:35 PM
NTChrist's Avatar
You are THE man.
As far as repairing your block goes, is there any reason that it can't be replaced?
Sounds like you've got a lot of work to do, repair, replace, whatever. Good luck.
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
Veaceonee
South West Region
Sep 6, 2015 10:04 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
Cacike
Aug 27, 2015 05:10 PM
