a really simple question...
Old Dec 7, 2002 | 08:11 PM
KsKid's Avatar
how can i get my heater in my car to warm up faster? its freezing outside and leaving my car runing in the garage for 5 minutes isnt warming junk up enough. after about 5 miles of driving it gets warm but up untill then i'm friggin freazing. thanks
Old Dec 7, 2002 | 08:22 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Put a piece of cardboard in front of your radiator, that covers abot ¾ of it.
If you have a mechanical fan, make sure it has a good fan clutch. Get a new one if you have any doubt. Don't get a cheap one, get a thermostatic one; it will have a little coiled-up thermostat on the front of it.
Old Dec 7, 2002 | 09:06 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
See below
Old Dec 7, 2002 | 09:07 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
160 degree thermostat would be a start.
Old Dec 7, 2002 | 09:28 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
It's funny you mentioned this, I just finished up a few hours ago. I dropped a 195 degree thermostat and my troubles were over. Mine never registed past the first line on my temp gauge, but at the time I had a 160 degree in there. For some reason, and I'm not really sure why, but most F-bodies I've come across just naturally take longer to warm up. But the higher temp thermo will warm things up better.
Old Dec 7, 2002 | 09:45 PM
KsKid's Avatar
this might be dumb but i dont throughly know much about cars yet. why cant i just take the thermostat out? the gauge doesnt work anyway.
Old Dec 7, 2002 | 09:49 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Technically you can. but not advisable.
On a computer controlled car it can play havoc on the computer.
Sometimes no stat will be fine, in letting a car run cool, other times it may cause over heating.
Old Dec 7, 2002 | 09:56 PM
racereno's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: Stock
Thundering,
Ya know, lookin' back, I've had some cars that preferred a higher therm and some that wanted a lower so I guess its just experimentation.
Old Dec 7, 2002 | 09:59 PM
KsKid's Avatar
its an 83 berlinetta... the majority of the car is not computerized. i changed the carb to an edelbrock and then i had to change the distrubutor becaues they didnt work together. theres hardly anything computerized left that i can think of. soon the emissions crap will be yanked out so there goes a little more...
Old Dec 7, 2002 | 10:06 PM
Car: 99 Formula
Axle/Gears: 342
Then summer time, I'd go 160* and minimum of 180* in winter, that's what I do.
Old Dec 7, 2002 | 10:07 PM
KsKid's Avatar
...nevermind
Old Dec 7, 2002 | 10:18 PM
Engine: 305 TBI
Yeah, experimentation. That's a good word for it. I'm like Mark, and it's funny he mentioned this, but it's exactly what i do.. I run a 160 in the summer, cuz mine runs hotter than I'd like it to, and I change back to 195 for the fall/winter. It's not a difficult thing to do so I don't mind. As for not running a termostat at all....hmmmm,.....I'm with Mark again,....I wouldn't advise it. Especially wintertime. You'll freeze to death.
Old Dec 7, 2002 | 10:52 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
im afraid youll just have to wait... Theres about 550 some odd pounds of cast iron and steel that has to warm up first before the t-stat will open and start flowing coolant. Takes alot of energy to warm everything up. Aint like my moms honda with a little aluminum straight 4 taht warms up in a jiffy. Gotta wait for heat in my car. And witht he low temp t-stat the heat is luke warm at best.
Old Dec 7, 2002 | 11:04 PM
TBI305Camaro's Avatar
Heat?!?! WTF is that??? Heater core??? Huh???
Haha...snowing here and ive been a week without a heater. Heater core went out last weekend and I have yet to fix it. Dash is halfway out but still no luck.
Computer?!?!? You mean that thing under the dash...I mean in my backseat
Im running a 180 degree thermo, cool fan switch (still works even without the computer) and it takes my car at least 7-8 minutes to warm up even alittle. Even when the holley has the choke fully closed and its idling WAY high. It is driveable right after starting tho.
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
