Car won't start now
Old Dec 10, 2002 | 10:06 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Car won't start now
I put in a new cd player and powered sub. Well all worked fine then power went out on the player. I have power everywhere except the cd player. All the fuses are fine. I tried to start the car and now it won't start. There is a loud grinding sorta noise coming from the engine bay. I think it's the alternator. I put new speakes in yesterday and the car started fine.
Old Dec 10, 2002 | 10:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
That grinding noise, I would bet is the starter.. Is it coming from the pass side of the motor?
Old Dec 10, 2002 | 10:20 PM
I don't know
Would installing new audio stuff have an effect on the starter? When I try to start the car the lights get dim and that noise starts. Could I need a better battery?
Old Dec 10, 2002 | 10:26 PM
Car: 99 Formula
Axle/Gears: 342
Re: I don't know
Installing that stuff shouldn't coudl be a coincendence, but the fact that your lights dim, makes me think it's something else.
Hmm, maybe someone else can shed some light here.
Old Dec 11, 2002 | 03:43 AM
rezinn's Avatar
It's normal for your lights to dim when you try to start the car. We can't really diagnose a noise without hearing it, but grinding when you're starting the car typically means that your starter isn't lined up properly. That normally doesn't just happen randomly.
Old Dec 11, 2002 | 02:30 PM
83tranzam's Avatar
Car: 1985 Trans Am
Engine: LB9 5.0 TPI
Is it really a "grinding" noise? Back when my battery went dead, it made a ticking noise. From what you described, it doesn't sound like the starter should be affected....
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
