Voltage Varies 10-14
Old Dec 11, 2002 | 08:15 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
I just noticed at idle I'm under 12v and the lights dim, when I rev it past about 900rpm it picks back up.
What would casue this, I put new terminals on but that did not help,
Bad Ground?
Old Dec 12, 2002 | 08:04 PM
Vader's Avatar
Are you using underdrive sheaves? It sounds like the alternator cannot keep up with load, either from excessive load, inadequate RPM, or a failing field winding or possibly a rectifier.
Old Dec 12, 2002 | 09:04 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I would try to get the alt tested and see if it is not bad or weak.
Old Dec 12, 2002 | 09:12 PM
82camaro's Avatar
Car: 82 camaro SC
What is your idle speed when it shows the low voltage--could be a slow idle. If the idle is OK, the alternator might be getting weak.
Elephantismo
Feb 13, 2019 12:51 AM
327IROC85
Sep 23, 2015 12:11 AM
eustodp
Sep 20, 2015 05:09 PM
ULTM8Z
Sep 16, 2015 09:15 AM
RyanJB
Sep 2, 2015 01:27 PM
