turn signal lever...
Old Dec 11, 2002 | 08:51 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
ok... my turn signal/wiper/brights/c.control lever is all messed up, I took out cruise anyway so I nabbed a lever from a 87 pontiac 6000 (it just pulled out of the switch/cam thing). I tried pulling mine out but I messed it up even more My question is - How do I get it off? Do I have to pull the steering wheel off?
Old Dec 12, 2002 | 09:37 AM
Vader's Avatar
The base of the lever is attached to the turn signal switch with a screw. The steering wheel must be removed to access this screw.
Old Dec 12, 2002 | 04:40 PM
dans82bird's Avatar
Engine: 302
I got it out last night, just a quarter turn and it popped out, the cruise control wires I just fished out through the steering column
Old Dec 12, 2002 | 08:22 PM
Vader's Avatar
...but the base of the lever is still in there on the turn signal switch. If you have a switch problem (not just a lever problem) you'll have to remove the wheel.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
