tapping heads for screw in rocker studs
Old Dec 13, 2002 | 06:25 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Is it really hard to tap it straight ? should I just let the machine shop do it?
Old Dec 13, 2002 | 08:31 AM
ede's Avatar
ede
if you use studs with a hex instead of the repair type you'll need to machine .4 off the boss. i've tapped a boat load of them, use a drill press to keep the tap straight.
Old Dec 13, 2002 | 09:43 AM
Vader's Avatar
If you are simply installing collarless studs, you can use a tapping guide to start the tap squarely. They are about $15 at most speed shops, and double as a stud pulling spacer.
If you're planning to install hex collared studs, follow Ed's advice.
db057
Sep 4, 2015 07:57 AM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
