Freakin oil filter
Old Dec 14, 2002 | 06:20 PM
WaynesRS's Avatar
Freakin oil filter
I started changing my oil today . The filter was put on so tight by the mechanic that I have torn it up trying to get it off . Only a small portion of the metal is on at the end where it screws in .and its stubble metal .I first tried putting a screw driver in it to get it off , and that just destroyed and tore and ripped the filter off ..HELPPPP !!!!!!
Old Dec 14, 2002 | 07:40 PM
Vader's Avatar
Wayne,
Presuming this is a Chevy V engine, try getting a sharp chisel on the remaining base of the oil filter and chase it around (counter-clockwise, of course) until it is loosened. I've had some real S.O.B. filters, too.
Old Dec 14, 2002 | 07:57 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I'd follow the above advice, except I'd use a brass drift punch instead of a chisel..if the brass punch started to fray, then I'd switch to a regular punch...then chisel as last resort.
Old Dec 14, 2002 | 09:00 PM
TBI305Camaro's Avatar
damn this is why I do my own oil changed. Next time its hard to get off get a screw driver and a hammer. You can figure it out from there
Old Dec 14, 2002 | 10:04 PM
1982chevycamaroz28's Avatar
thats why i do mine also. some place that ive heard use air wrenches to put the filters on instead of using the fricken hands to hand tighten it.
Old Dec 14, 2002 | 10:07 PM
WaynesRS's Avatar
Thanx guys !
Yeah , I usually do my oil change but , it was in the shop and they said it needed changing , long story guys . But , I'll be damn if they changed it again . I think they must have put a torque wrench on it and tightened it down as mush as they could .
Old Dec 14, 2002 | 10:08 PM
WaynesRS's Avatar
Yeah , I tried that method , it was so tight on there I just started making the holes much bigger because it was not moving . I wish I could post a pic of this filter , its like destroyed except whats left on the car still .
Old Dec 15, 2002 | 10:32 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Hey Wayne,
You might be able to remove the filter boss...and work it out on a bench with a bit more room to spare.
Old Dec 15, 2002 | 01:18 PM
WaynesRS's Avatar
8Mike9 ,
Thanx man . Yeah , it is pretty tight under there . I finally got it off though . I had to put a screwdriver in one of the flange holes and tap it out of there with a hammer .Then I got to have more fun with the oil plug on the pan that must have been torqued on there to 250 pds ..
Old Dec 15, 2002 | 03:27 PM
NTChrist's Avatar
Check the threads on the oil pan, the plug, and the filter base.
Make sure none of them are stripped, stretched, or damaged.
Real pain in the butt when you pull an oil plug out of a pan that's been damaged by overtightening, and the oil pan threads come with it...
Old Dec 15, 2002 | 04:46 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
Did you call the shop that did the work and complain? I would, cant stand slopy work from people that are supposed to be professionals.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
