car acting weird
Old Dec 17, 2002 | 08:47 AM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
car acting weird
The last like 2 days my car has been acting kind of weird, its idling lower than normal, and when its idling all of my lights get dim if there on, when i give it a lil gas they brighten up, also when i let off the gas in gear its popping louder than normal, it backfired once yesterday, i was thinking the light problem was my altenator but what would cause the other stuff?
Old Dec 17, 2002 | 09:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like one cylinder is misfiring, and when you goose the gas, the extra unburned fuel that is passing through the engine, is getting ignited by the other cylinders' exhaust. And of course the RPMs come up to a point where the alt can generate enough electricity to satisfy the car's demand. Everything you describe is pretty normal for a motor that needs a tune-up.
Old Dec 17, 2002 | 12:03 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
the engine only has like 4k miles on it, it has always had a little miss in it, if you stand in by the exhaust while its idling you can hear it miss every once in a while but ive never been able to figure out why, its got all new plugs, accel 8.8 wires, i replaced the coil with a flamethrower(that helped a lil bit) any ideas on why it could be missing like this? makes me wonder what i could run on all 8
Old Dec 17, 2002 | 12:52 PM
Ace_Murdock's Avatar
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
have you checked your distributor?
maybe one of the contacts could be corroded, or worn down.
Old Dec 17, 2002 | 12:53 PM
Car: 1985 Z-28
Engine: a big one
also do you have EFI? maybe one of the injectors could be dirty
Old Dec 17, 2002 | 01:10 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
no its carbed, the carb was just rebuilt, it has been running a lil rich, could be the distributor
Old Dec 17, 2002 | 01:25 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
you didnt mention that you changed the cap and rotor.
and you should also check the timing.
when my timing gets a little retarded it will do what you are describing.
check initial timing and makes sure it advances when you give it gas.
Old Dec 17, 2002 | 01:27 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
your right i forgot to mention that but the cap and rotor were also replaced when i put the engine in, my timing should be fine i havent messed with but ill go advance it a couple degrees and see if that helps...
Old Dec 17, 2002 | 01:31 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
also you could have a plug wire grounding to something...
it would cause a miss and your poping exhaust and would also be a large drain on the electrical.
Old Dec 17, 2002 | 01:34 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
do mean by that like if the plug wire melted on the exhaust that it could being grounding out on the exhaust? could be a problem also...thanks guys
Old Dec 17, 2002 | 01:52 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
yes
no problem
Ghettobird52
Jul 5, 2024 11:18 PM
maroe624
Apr 16, 2017 08:29 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
novaderrik
Aug 10, 2015 12:44 PM
gwade12
Aug 8, 2015 08:17 AM
