me thinks its the heater core
Old Dec 17, 2002 | 01:43 PM
daniel dekay's Avatar
my heater still works, but it reeks of antifreeze. my defroster seems to spit out dust of some sort on the windshield and when i stop the engine smoke comes out of the vents.
does this sound like a heater core problem? if so, how much can i expect to dish out for a replacement and labor. i heard it takes as much as 8 hrs to replace.
thanks
daniel
Old Dec 17, 2002 | 02:10 PM
camaro_1983_383's Avatar
yeah, i had a explorer that did the same thing. it was the heater core. fortunately, they are very easy to change in a third gen, so you dont have to have someone else do it. i think they are about 30 to 50 bucks. do a search of other threads about this, because i read a thread a few weeks ago and a guy wanted to change his and people posted pictures and instructions.
Old Dec 17, 2002 | 02:26 PM
Enkil's Avatar
Yeah, sounds like a leak in the heater core. That "engine smoke" is antifreeze/water/etc. The core itself should only be about 15 bucks, and to replace it all's you have to do is take off the kickplate on the passenger side. (The core is on the passenger side of the car.) If you can't get it out from there, take off the top of the dashboard. And if you still can't get it, just keep taking things apart. Experienced people can change the core in 10-15 minutes, whereas new people might take a lot longer. Not worth paying somebody to do, though.
Old Dec 17, 2002 | 03:19 PM
cool, thanks alot for the advice.
daniel
Old Dec 17, 2002 | 04:07 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
If you take it to a shop they will ring you up about $500 - $600 in labor for that job. It can be done at home but it is a pain. Patience will be the key. The top bolt on the heater box will be the most difficult part. It is right under the speaker on the passenger side.
Do a search on this board. I and others have written on the topic several times. I did my '92 camaro and now I think I will have to do the one in the '87 Trans Am I just bought. What a pain!
Lay down some towels or plastic or newspaper when you take the heater core out. It will leak anti-freeze.
Old Dec 17, 2002 | 04:51 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
its really easy in an 86 just take out the kick panel. that all u should have to take out. and that top bolt it going to be a pain in the A$$.
Old Dec 17, 2002 | 06:37 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
i smell the funk also and i would like to replace mines, but some shop guru told me that i would have to deplete my ac and recharge and he would rape me for 550. i want to do it by myself, do i really have to mess with the ac??
Old Dec 17, 2002 | 06:40 PM
azvolfan's Avatar
I am not aware of having to do this in any thirdgen. Did not have to mess with the a/c in my '92.
Old Dec 18, 2002 | 03:03 AM
Enkil's Avatar
Your mechanic offered to rape you for $550? You REALLY need to get another mechanic. No, discharging the AC is NOT necessary. The heater and the AC are two completely seperate systems -- at least, in regards to the part that "heats up" and the part that "cools down" the air. You'll drain some of the engine coolant when you take off the heater core, since the heater core uses the heat from the antifreeze to warm the air blowing into the interior, but that has nothing to do with the AC.
550, that's absurd! Back when I didn't know any better I was charged $150 for parts and labor.
Old Dec 18, 2002 | 10:02 AM
Vader's Avatar
Not to side with anyone, but it your "funk" is from debris and mold accumulation on the evaporator (not uncommon) the evaporator case would have to be opened, and possible the evaporator coil would have to be removed, in which case the system would have to be evacuated.
If you are experiencing the sweet aroma of antifreeze, your problem is likely the heater core. If it smells like dead rodents, you may have growth in the evaporator.
Old Dec 18, 2002 | 12:58 PM
luvrgodd's Avatar
Car: 02 Z06
Engine: LS6
Transmission: MN12
nope its not funky funk its just the sweet smell of antifreeze. i think i will try to take it off myself.
Old Dec 18, 2002 | 04:36 PM
azvolfan's Avatar
Actually I called several shops and they all said the same thing. They said they had to remove the dashboard and all were in the $550 - $600 area. That is when I decided to do it myself.
Old Dec 18, 2002 | 05:02 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
to get that top bolt i got a tiny 7mm wrench and got at it from the top with the dashpad off.... didnt put it back on...
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
