Timing For Trans Am????
Old Dec 18, 2002 | 10:06 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
What is the correct timing for a 1986 Trans Am, LG4 305cid, Carb?
Old Dec 19, 2002 | 08:26 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC factory setting is 0° with the EST connector disconnected. The car will run much better at 6°.
Old Dec 19, 2002 | 09:42 AM
Vader's Avatar
You recall correctly.
Old Dec 19, 2002 | 12:59 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Stupid question but what does IIRC stand for?
Old Dec 19, 2002 | 01:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If I recall correctly, it stands for "If I Recall Correctly"....
Old Dec 19, 2002 | 01:16 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
thanks -- i didn't recall correctly
Old Dec 19, 2002 | 05:34 PM
Engine: LG4 305
Do I bring up the # 1 cylinder or # 6 cylinder on compression stroke when I'm timing it????
Old Dec 19, 2002 | 05:38 PM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
Are you adjusting the initial timing??? You don't need to worry about bringing anything to TDC. Hook the timing light to the #1 plug (the front right one) and shoot. Just in case you didn't know, clockwise retards and counter clockwise advances (the distributor that is) IIRC.
Old Dec 19, 2002 | 05:44 PM
Engine: LG4 305
I'm putting a new distributor in the car.
I need to know if you set the roter on the distributor at #1 compression stroke or #6 compression stroke???
Old Dec 19, 2002 | 06:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
Whichever you took the old one out at, put the new one in at the same spot.
Old Dec 19, 2002 | 06:20 PM
Engine: LG4 305
the old distributor was out of time.
Old Dec 19, 2002 | 06:28 PM
No4NJunk's Avatar
Doesn't matter too much. Just as long as the rotor is pointing at number 1 plug on the cap. Go from there. Dist only goes in two directions so putting it back into its original place shouldn't be hard unless you have moved the oil pump shaft in the process of removing the older dist.
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
jharrison5
Aug 19, 2015 05:53 PM
Exxon Limited
Aug 9, 2015 08:13 PM
