emissions
Old Dec 21, 2002 | 05:09 PM
badazz84camaro's Avatar
emissions
i just got my emissions statement today, what do all you guys that build your camaros and firebirds do when you have to go for emissions? how do i fill it out? i need help, will all the things in my sig, i dont think i will pass, what do you guys think?
Old Dec 21, 2002 | 05:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An "emissions statement" that you fill out? I've lived in Colorado and California (to say nothing of Germany and Japan), and have never had to fill out a form giving information about the car. Don't ever recall hearing about it, either.
What type of questions are you supposed to answer?
Old Dec 21, 2002 | 07:07 PM
MasterEvilAce's Avatar
never heard of this either
Old Dec 22, 2002 | 12:03 PM
its not a statement, its a notice saying that i am up for emissions, my car is currently inoperable because im am painting it. what shoud i do, if i put my car is currently inoperable, will they still renew my license plates? what do you guys do when you have to go for emissions.
Old Dec 22, 2002 | 01:27 PM
well my first guess would be to tell them it's getting painted, so you won't be driving it for awhile.. and that you'll get it inspected for emissions As soon as you can.. if you're not driving it, no harm can be done.
never heard of these notices before.
even here the thirdgen we have, the guy before us was supposed to get it inspected in june or july. many months before we got it.
Old Dec 22, 2002 | 01:46 PM
i dont think my car will pass though
Old Dec 22, 2002 | 01:58 PM
Here, if you don't pass the first time, i BELIEVE the second time is free... and any other time after that you have to pay.
I think that's how it works.
might as well try, though. you'll be able to see what problems it has with what
a tip that people say on this forum is to make sure your car is hot (drive it around for 30 minutes or so prior to getting it inspected)
the hotter it burns the better the exhaust is or something.
Old Dec 22, 2002 | 04:20 PM
should i put a smaller carb and a cat on too? and maybe advance the timing a little bit
Old Dec 22, 2002 | 10:37 PM
FJK's Avatar
FJK
In Illinois, if you tell them your car is inoperable, you need to also provide an estimated date when the car can be tested. This should not affect you renewing your plates. Since your car is so heavily modified, I'd take the test for the first time, just to see where you stand emissions-wise. On a car with a carb & distributor, you can tune your way into acceptable emissions (but you would not want to drive it that way. These are things that help.
For CO, set you idle mixture screws lean & increase your low idle to ~ 1000 rpm ( do not excede 1300 rpm).
For HC, retard the timing as close to 0 deg btdc as possible.
Set your timing first, then adjust the carb to the conditions I described.
With your double pumper, I would disconnect the secondary pump & loosen up the primary pump. The whole object is to prevent alot of excess raw fuel increasing your HC number.
All the tricks assume you have a properly operating ignition system & carb. Plugs & wires are fresh, the carb has no operational problems.
If you have an air pump on the car, make sure it is functional during all operating conditions.
If, after the first test, you flunk & the emissions are really high, meaning you are going to have to "try things", be advised of this. You can "buy" a volantary test for $20. The results will not count toward your offical 3 test maximum. The point is, if you flunk your third test & go for a waiver, you might not get it if your are missing emission control equipment. You are better off passing the test without them looking over your car.
Hope this helps. Good luck.
FJK
Old Dec 22, 2002 | 10:44 PM
thanks, i will try when i go this spring, right now the car is away for the winter, what about if i get show/race car insurance?
Old Dec 22, 2002 | 10:49 PM
Black84Z28's Avatar
A couple days before I go to get it inspected I drop the LG4 with all the emissions equipment back in it, and I bolt the stock exhaust back on. It's a real pita but it's damn worth it. Ever try to make an LG4 car fast while staying emissions legal? It ain't happening.
Old Dec 22, 2002 | 10:55 PM
FJK's Avatar
FJK
Yeah. I've heard about that. I know guys get waivers by providing documentation (photos & insurance statements) that the car is for show or race. I don't know that much about it to offer any comments on what needs to be done. Why don't you do a search for the website for Illinois vehicle emissions testing? My guess is you could find out that information there.
my car was originally a v6 too, will that affect me, or do i just tell them it has a v8 in it?
Old Dec 26, 2002 | 02:02 AM
87TA 305TPI's Avatar
im not sure about sauk villiage but im in chicago and they give you plenty of time to have it tested, more than enough to paint it then test it without telling them anything. the first form for my winter car said i had untill august but they just kkept sending them untill i got a final notice to have it tested by the end of november and when i didnt pass the first time in november they gave me longer yet but there is a place in southwest chicago that guarantees to pass any emission test for $165, i think they just pay someone off but it got me through. you have to let them take it in for the test though, its called Shield's and its in summit actually, not chicago but its SW of chicago. i dont know if its poccible for you to go there because i have no clue where youre at but good luck...
Hotrodboba400
Dec 10, 2019 07:07 PM
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
TBRays98
Sep 6, 2015 05:05 PM
