91 Z just died
Old Dec 22, 2002 | 09:17 PM
gofast22's Avatar
91 Z just died
hey all my 91 Z just died cruzing down the street . fuel pressures good sparks ok . i checked the injector pulse and its not pulsing but staying on constant .like its in fuel fuel load but the tps readings are fine and no codes. strangest thing i have ever seen !!!!!
i think the computer took a **** anybody ever seen this ?
Thanks Doug
btw 91 Z 350 700R4 no mods
Old Dec 22, 2002 | 09:47 PM
rezinn's Avatar
If the injectors aren't pulsing then you already found your problem. Is it flooding? How do the plugs look?
Old Dec 22, 2002 | 09:52 PM
gofast22's Avatar
91 Z
i havent checked the plugs yet i got a nasty *** cold so i had it towed to my shop and only played about 30 mins . but ges im smelling fuel and its not leaking anyplace .i know what the problem is but what is causing it ?
Old Dec 23, 2002 | 10:12 AM
Vader's Avatar
If the 'noid light stays on constantly, you may have a ground in the wiring harmess for the injectors (including a shorted injector).
EDIT: Can you say "Multec"?
Old Dec 23, 2002 | 07:47 PM
gofast22's Avatar
thanks for the responces i bought a remaned ECM today and my girl runs fine .
Thanks Doug
Old Dec 24, 2002 | 10:47 AM
Vader's Avatar
Random ECM failures are VERY rare. Something took out the switching transistor for the injectors, and I'd still advise checking the resistance of the injector solenoids. 10.5 is the bare minimum cold resistance for your Multecs.
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
