just a stupid question
Old Dec 23, 2002 | 02:50 AM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
What exactly is involved with a good tune up?
Old Dec 23, 2002 | 03:56 AM
radiateu2's Avatar
tuneup
plugs, wires,cap and rotor if it applies, filters =fuel oil air pvc vapor cannister, checking timing belts hoses scan enginefor error codes pvc valve replaced I also include the tranny filter and fluid check battery and cables Check radiator for leaks pressure test check power steering fluid and system for leaks check master brake and tranny res for proper fluid level. Cant think of anything else I check for at the moment. oh tires for wear and pressure
Old Dec 23, 2002 | 10:29 AM
Vader's Avatar
"Tune UP" is a little different from "Scheduled Service". If you are tuning the engine, there are some basic steps.
A basic tune-up MUST include:
* Cooling system inspection;
* Clean or replace spark plugs;
* Ignition wire testing;
* Distributor cap/rotor (if you don't have the OptiSpark);
* PCV valve cleaning or replacement;
* Air filter;
* Cleaning the IAC;
* Checking/setting TPS voltage;
* Check/adjust minimum air rate;
* Check/adjust timing;
* Code scan;
If you are performing Scheduled Service based on usage or mileage, the service items will be different.
Cleotiz
Jan 6, 2018 08:56 PM
3.8TransAM
Sep 3, 2015 06:38 PM
masonta
Sep 1, 2015 06:40 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
