My Car Won't Start
Old Dec 24, 2002 | 10:48 AM
91Rskid's Avatar
My Car Won't Start
Here is the scoop, I turn the ignition and nothing happens. I am thinking that it might be the starter. But, I am not sure if it is the VATS. Does anyone know?...
Old Dec 24, 2002 | 11:11 AM
Dirty Rob's Avatar
Does anything else that requires electricity work?
Old Dec 24, 2002 | 12:04 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
first thing i'd do is check the wires to the starter.. see if they're on correctly and such... if they are pullem off and hook up a test light and see if it lights up when you try to start the car.. then your pretty much limited to a starter or solienoid... make sure ya defently look at the wires first though... the heat shielding on one of mine was ever so slightly melted from the heat of the headers before and gave me a buncha nice green fuss inside that stopped my starter from doin ne thing.. just replaced the wire and rerouted it a lil farther from the heat
Old Dec 24, 2002 | 12:08 PM
91Rskid's Avatar
Everything else that requires electricity works. My CD player, headlights, and my idiot lights come on too.
Old Dec 24, 2002 | 12:13 PM
Dirty Rob's Avatar
Best to follow 89's advice then, while youre down there, check the fusible links as well.
Old Dec 24, 2002 | 12:53 PM
91Rskid's Avatar
Thanks, hopefully this works
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
