wtf reusable gasket....
Old Dec 25, 2002 | 07:34 PM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
OK on my daily driver a 93 blazer i got an oil change at jiffy lube and they told me there was gas in the oil and the guy smelled it i smelled it so i took it to the dealer twice because i was getting bad gas milaege and i checked the oil everyday and kept on smelling it. Well they said theres nuthin wrong and they took of the manifold but used a reusable gasket....... well tonight the blazer had a hard time starting(the engine was warm too) then the check engine light came on and it smells like firecrackers rotten eggs sulfer and the oil pressure is slighlty low and it idles rough. I no this is not about my thirdgen but its winter and i need help please help.....thanks
Old Dec 25, 2002 | 07:51 PM
rezinn's Avatar
Oil pressure has nothing to do with the intake, although the rough idle could be caused by a bad gasket. I'm assuming the gasket is good since they left it alone. Sounds like you've got some other problems, though. You should have the code read somehow to see what that tells you. Are there a lot of miles on this engine? Sounds like you may have some bad gas or something wrong with your smog system.
Old Dec 25, 2002 | 11:11 PM
breathment's Avatar
bring the dang thiing back and tell them they screwed something up.. thats always the fun thing to do...
Old Dec 26, 2002 | 12:23 AM
Vader's Avatar
Hard starting? Poor idle? Sulfur odor? Sounds lean to me.
First, what engine is in the Blazer?
Second, what "manifold" did they remove and replace? If it's a split upper plenum on an MPFI they may have reused a gasket. A 4.3 V-6 has only rocker gaskets that can be reused.
Third, what error code(s) are you getting?
83 Crossfire TA
Jan 3, 2016 01:26 PM
BOOT77
Sep 16, 2015 08:37 PM
gta892000
Sep 16, 2015 12:37 AM
DARKmj16
Sep 9, 2015 04:07 PM
