Need help bad
Need help bad
Ok,
I switched from TPI to Carb
305
88 IRoc z-28
we got the carb, the intake, the new distributer all hooked up the car runs then dies, the intank pump is still in but unplugged
i have a holley7-9 psi in the nose of the car right in front of the carb and it pulls through the disconnected intank pump
we are using a regulater still but the problem is the pump in the nose will run sometimes and then sometimes it wont...someone told me that the intank pump puts out 120 PSI and it wont take any kind of regulater, hence why i have the other pump pulling through the in tank pump. do they make a regulator for this?
305
88 IRoc z-28
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
A TPI pump only puts out about 45-50 psi. You can put a regulator on it also....Who told you it puts out 120psi????? That is one hell of a pump then.
USe you intank pump and put a regulator on it ...you'll be fine
USe you intank pump and put a regulator on it ...you'll be fine Supreme Member
Engine: T.P.I L98.
Transmission: TH350
Try using the search option on "fuel reagulators" It will give you all topics along this line and will answer more questions for you then I can. Hope this helps.
Keiran
Keiran
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I think you want the Mallory three port fuel regulator. That is what I am using on my TPI to Carb swap with no problems. The Jegs part number should be MAA-4309
on the phone with JEGS now..and the guy doesnt think it'll work...every one i have talked to so far says its not even possible...they're saying im gonna have to drop the tank and gut the pump....ok hes back...ok they're saying the 4309 will work because of the return lines...hmmm i just wonder if i should pay the 74.99 or drop the tank...
dimented24x7
Sep 17, 2015 06:58 AM
