pulley bolt tension
Old Dec 30, 2002 | 11:25 AM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
pulley bolt tension
how important is it to get the pulley bolts on as tight as possible, how tight is sufficiant?
Old Dec 30, 2002 | 11:40 AM
ede's Avatar
ede
well you wouldn't want one to fall off. i use the "real damn tight" method along with red loctite
Old Dec 30, 2002 | 01:21 PM
Vader's Avatar
What "pulley" are you asking about? The torque spec for the water pump sheave/fan is 20 lb/ft, but those are only 1/4-28 bolts or studs. If you mean the bolts for the harmonic balancer sheave, those are usually 3/8-16 bolts and should be torqued to 35 lb/ft.
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
lakeffect2
Sep 7, 2015 03:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
