Fog lights - is there a relay?
Old Jan 3, 2003 | 06:29 AM
The Josh's Avatar
I cannot get my fog lights to work. I checked the fuse and bulbs and they are fine. When the headlights are on and I switch the fog lights, the green light in the switch is on but no fog lights.
Is there a relay I need to check? If there is, can someone tell me where it is located? Or is there something else I need to check...
Thanks in advance.
The Josh
PS - I decided against the TTA...
Old Jan 3, 2003 | 09:15 AM
The Josh's Avatar
Oh, by the way, it is a 92 Camaro Z28 350. I saw another post that said it was next to th horns. Is that correct?
Old Jan 3, 2003 | 11:04 AM
Vader's Avatar
Josh,
I'm not sure on the Camaros, but on the Firebirds there is a relay along the firewall, near the brake booster.
Old Jan 3, 2003 | 12:02 PM
The Josh's Avatar
OK. Any idea what the part number is for the relay? I figure i will just buy one and see if it works...
Old Jan 6, 2003 | 06:36 AM
The Josh's Avatar
OK, got under the hood this weekend and DID NOT FIND THE RELAY! Could it be under the dash?
Also, I checked the fuse again. It was good. Then I put a meter on it and turned the lights on. I got no voltage to the fuse.
Is the fuse upstream of the relay or downstream in the circuit? That would tell me a lot.
Can anyone help me please? Also, is there a GM tech number I can call for help with this???
Thanx...
GTAman
Mar 15, 2019 11:40 AM
PATRIOTIC1911
Sep 1, 2015 07:26 PM
SlowAZ28
Members Camaros
Aug 31, 2015 07:53 PM
tealman92
Exterior Parts for Sale
Aug 27, 2015 11:21 AM
mustangman65_79
Aug 12, 2015 06:39 AM
