Please Help, my engine is stalling
Old Jan 3, 2003 | 03:41 PM
fmsracing's Avatar
I put a new 383 cid in my 1988 GTA (700R4) after it sat for 3 years in my garage and it is throwing a code 24 only when I put the car in gear. When I try to give it some throttle, the car starts to go and then dies within a few feet and acts it has no fuel and that is when the code sets. However, when I put it in neutral the engine revs smoothly to 5000 rpms with no problem. I put a new: walbro 255 l/hr pump,a hotwire kit from racetronix, a new fuel pressure regulator and a new fuel filter. The fuel pressure is steady 42 psi w/vacuum line on and 50 psi with it off. The new injectors are 28 # from Lingenfelter and it has a ECM chip for this setup from Performance Resource. When I first got the car running it ran fine for about two miles and this problem started. Since then, I have yet to get it out of my driveway. I believe the problem is in the electronics and not mechanical but I do not know how a code 24 VSS would effect how the engine runs. BTW, the spedo works fine. I have done a search on this board and have found several people that had a problem w/performance or the engine dieing and a code 24 setting but I can't find a post where they tell what they did to fix the problem.
Paul
Old Jan 3, 2003 | 03:52 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Old Jan 3, 2003 | 03:59 PM
fmsracing's Avatar
I have checked all the grounds at the back of the heads and they are tight. The battery is in the trunk and it has a 4 gauge ground to the body. The battery connections are tight. The strange thing is it only give me problems when it is in gear, it runs great in nuetral.
Paul
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Bryan F
Aug 18, 2015 02:28 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
