Need help diagnosing TPI woes.
Old Jan 5, 2003 | 07:01 PM
holmes677's Avatar
I just fired up my first 3rd gen and its an 86 Z with 305 tpi. It has some serious power problems along with many others. Ill list them:
1: NO POWER, wouldnt even break the tires loose in the rain
2: High idle, then likes to die when put in gear, idles at 1000- 1300 in park and 500-600 in gear if it doesnt stall out.
3: Hesitation: has horrible throttle response, takes longer than it should to rev up.
One problem i have to idea on is that the cat started to glow red. Somebody told me that the car is running way too rich and that would solve alot of the above mentioned problems but i am weary about just taking it to a shop and telling them to fix it. Any ideas are greatly appreciated. Thanks.
Old Jan 5, 2003 | 07:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like timing way retarded. Loose distributor hold-down maybe.
Start with the timing, set it to whatever the stock spec is (6° BTCD IIRC) and see if it's any better.
Old Jan 5, 2003 | 07:46 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
double post ...sorry.
Old Jan 5, 2003 | 07:47 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Over here too....https://www.thirdgen.org/techbb2/sho...hreadid=153109
If your cat is glowing and your exhaust manifolds aren't...it is most likely the cat that is the problem...it's plugged.
Old Jan 5, 2003 | 10:46 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Sounds like my false lean conditions minus the high idle, mine was really rough. You mentioned someone said it was running rich, does it smell rich? A blown intake gasket and loose ypipe bolts caused my false lean. How is gas mileage? I would check the cat first as mentioned earlier tho.
Old Jan 6, 2003 | 01:06 AM
holmes677's Avatar
Ive heard of people gutting they're cats, could i just do that in the mean time while a new one is on the way? How would i gut it in the first place?
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Thaney9
Aug 29, 2015 03:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Sanjay
Aug 12, 2015 03:41 PM
