Need dishedpstons for camel hump heads?
Old Jan 8, 2003 | 01:06 AM
Team P.S.I.'s Avatar
Car: 88 Z28
Engine: 408 Small Block
Transmission: TH350
Axle/Gears: 9" w/ 3.90's
Doy uo have to use dished pistons to keep a fairly low compression ratio?
Old Jan 8, 2003 | 01:35 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
it depends on what cc the heads are, what is the size of the combustion chamber of the heads you are using, and what size is the motor.
Old Jan 8, 2003 | 02:43 AM
Car: 88 Z28
Transmission: TH350
194/150
350sbc .30 over
Old Jan 8, 2003 | 05:30 AM
Engine: 383, L69
well if they are 305 heads they have 58 cc chambers, and 350 heads normally have 64 cc chambers, with the 58cc heads with flat tops you will be at about 10:1 or more, with the 64cc heads with flat tops you will be at about 9.2 - 9.6 should be good for daily street use. im going with dished pistons with 58 cc heads, ill be around 9.5 compression, the 305 heads only have 1.80/1.50 valves but they can be machined for bigger tho
Kevin
Old Jan 8, 2003 | 05:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If they're really double-hump heads, they're 64cc nominal. Valve size doesn't matter.
350 motors that came from the factory with those heads had either flat-tops, for about 10.3:1 CR; or domed pisotns, for about 11.1:1.
Here's the casting mark:
Attached Thumbnails Need dishedpstons for camel  hump heads?-head-casting2.jpg
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
