Car stumbles at high RPMs
Old Jan 16, 2003 | 10:59 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Ok here is the deal, my car was running strong (relative term here (305TBI) ) until yesterday, when i went WOT at about 3500rpm the car stumbled a couple of times, and then fell flat on its face. it seems fairly responsive until the revs go about 3500. if you guys could give me some ideas of things to check. the car has a new fuel filter, and the plugs looked good (2 weeks ago).
i am going to go pull a couple of plugs this afternoon. and check the plug wires. anything else i should look for?
ohh yeah 90RS 305TBI.
Old Jan 16, 2003 | 03:08 PM
ronterry's Avatar
Car: '94 Corvette
Almost sounds like a fuel pump. Throw that on the check list.
Did you mess with the timing? See what kind of timing reading your getting at 3500.
Ron
Old Jan 17, 2003 | 07:55 PM
Rustydawg's Avatar
Car: 86 Firebird
Engine: 355 4 bbl
Transmission: TKO 600
Axle/Gears: 3.73 L/S
I'm thinking low volume of fuel due to the fuel pump going south.
Old Jan 17, 2003 | 09:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, sounds like fuel delivery.
Just out of curiosity, why did you change the fuel filter? What did you find when you did it?
Old Jan 17, 2003 | 09:39 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
You said you changed the fuel filter right. Are you sure you got the flow direction right. Should have an arrow of which way the fuel should flow through it.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
squiggy2
Aug 9, 2015 09:30 PM
