starter sticks wide open!! pls help
Old Jan 16, 2003 | 06:57 PM
Nasty_Bird_'90's Avatar
I had to replace my starter the other day b/c it was acting up and one of the problems was that it would stick open occasionally. Today I went to start the car and low and behold, it stuck open. I had to disconnect the battery b4 it killed the battery. What would cause this?
Old Jan 17, 2003 | 07:15 AM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Sounds like somethin in your ignition switch or somethin. Like it is not releasing when you stop trying to start it. Or, maybe you bought a bad starter. If you bought it at advanced auto or autzone, that could be the case.
Old Jan 17, 2003 | 07:27 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I had this problem once it was because the 2 wires on the starter were touching each other (the ones that arent ment to touch each other...)
Damn thats pretty scary when your starter goes crazy and starts smoking...
Old Jan 17, 2003 | 07:50 AM
Luckily I got the battery discnnected before it started to smoke! I'm going to replace the ignition switch today ( that outta be fun). Then I'll check the starter wires. Thx.
Old Jan 17, 2003 | 06:35 PM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I had this problem once too. When I put the starter on I had it in a "bind". Try loosening the starter and holding it against the block so its flush with its mounting spot on the block. It may also be too tight against the flywheel/flexplate and needs to be shimmed.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
Formula_88AE
Sep 3, 2015 01:47 PM
