Charcoal cannister
Old Jan 19, 2003 | 10:54 PM
Joeboy's Avatar
Charcoal cannister
Can you remove the Charcoal cannister? I dont have an EGR,Air injection system,Cat,Muffler, or any of those systems. Can I eliminate the charcoal cannister as well?
Old Jan 20, 2003 | 12:14 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I did. The charcoal canister is used to vent the gas tank. The vapors in the tank are drawn into the canister and then into the carb or fuel injection system instead of venting into the atmosphere.
Old Jan 20, 2003 | 07:52 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Yes, you can. I have eliminated it on mine. The only real decision you have to make is what to do with the hardline that ran from the tank to the canister (this is the line the fuel vapors ran through and was joined to the canister via a rubber hose). There are two methods ...
1) Cap it. The Cons of this are that people will tell you that you CANNOT cap it because the tank builds pressure and it needs to be released. I have 2 friends running with it capped and they have no problems. Fact is - there are 4 lines coming from the tank ... feed, return, canister, and another that has a release valve to let excess pressure out and air into the tank.
2) Don't cap it but run a piece of rubber hose to a small import fuel filter and then tuck this into the front fender somewhere.
I took the second route.
Tim
Old Jan 17, 2005 | 02:58 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
hey traxion do you have any pictures of the filter you used. i couldnt imagine what would be small enough to fit onto that line.
Old Jan 18, 2005 | 11:13 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Here's the one I used. Apologies for the poor quality Nokia picture.
Old Jan 18, 2005 | 11:26 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
that looks like one used on a golf cart, hah, i worked repairing golf carts this summer and it just reminded me of that, maybe u could even use one of those, they are very cheap, maybe 3 bucks
Old Jan 21, 2005 | 01:50 AM
Spdfrk1990's Avatar
I think i might just cap mine maybe put a filter where the release valve is.
Old Jan 22, 2005 | 06:59 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
If you eliminate the can, I would also recommend getting a vented gas cap. Our cars are not as picky about this as newer EFIs, but why risk it?
Old Jan 22, 2005 | 07:05 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The whole purpose of the canister is to vent the fumes somewhere if pressure builds into the tank. Once you start the car, fumes get sucked into carb and burned in engine. I've had issues with this converting from CC Q-jet to DFI. It does serve a purpose. My old 72 chevelle had one, and that's before catalytic converters and emissions testing!!
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
TBRays98
Sep 6, 2015 05:05 PM
BurlyChev
Aug 16, 2015 09:08 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
