Hot lashing?
Old Jan 20, 2003 | 12:28 AM
Raiden's Avatar
Hot lashing?
I went to lash my valves with the engine running and I am a little confused. When I backed out the rocker nut, the rocker started clacking. As I put a few turns on the nut, the clacking got quiet. But it was still there, just a lot less noisy. I put not quite 1/4 turn till the clacking was completely gone. Then I put 1/3 turn on the nut. Am I supposed to consider zero lash when the clacking quiets down the first time? This is when it goes from loud clacking to quiet clacking. OR am I supposed to consider zero lash when the clacking stops completely?
any help is greatly appricated
Old Jan 20, 2003 | 07:13 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Sure valves and rockers are noisy. You will never get all of the clacking out of them. I use the crane gold full roller and when I am hot lashing I back them off until they clack then take them down until the motor has a slight miss to it and back it off until the miss goes away.
Brian
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
