Raise Compression on Higher Milage engine?
Old Jan 20, 2003 | 09:11 AM
snowbird's Avatar
I've got a 94 TBI 350 engine. It has about 120,000 miles on it and ran great and burned no oil when pulled. I was planning on putting a set of LG4 heads on it to raise compression. Do you see any problems arising with doing this because of the mileage?
Old Jan 20, 2003 | 10:04 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Not really. Just be aware that you'll need to run higher
octane gas, because of the higher compression ratio.
Also the flow of stock LG4 heads is quite modest.
But once you've fully ported them and put in larger valves,
they'll work nicely.
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
toronto formula
Nov 10, 2015 06:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
