Car is shaking WAY too much..............
Old Jan 20, 2003 | 05:16 PM
FLYNLOW92rs's Avatar
The other day, my starter relay went bad, i tried starting the car several times to no avail.......
Anyway i took off the Open element cleaner for a second to check things and put it back on....
NOW the car is rumbling alot more, idle, half & full throttle........
What's seems to be the problem, the car ran fine before, then all of the sudden it's shaking more and seems like something is wrong.....
almost like a constant rumbling, that wasn't there before....
What could be the problem or what should i check, thanks in advance.......
Old Jan 20, 2003 | 09:27 PM
Alan84TA's Avatar
You might check your balancer on the front of your crank. It is not uncommon for them to sparate from the rubber..
Old Jan 20, 2003 | 09:50 PM
NTChrist's Avatar
Hooked up all the vacuum lines again?
Old Jan 21, 2003 | 10:04 AM
I didn't remove any vacuum lines, but where should i check for them incase they are bad??
I'll check the balancer when i get home..
Old Jan 21, 2003 | 05:59 PM
It idle's way too high also, and the stumbling seems to cease to exsist after about 2k rpms......
Old Jan 21, 2003 | 06:36 PM
89WS-6's Avatar
Sounds like a vacuum line, dont mean to try to put you down, but they should come off the TBI, and go to the bottom os the air cleaner, and one I think over to the heat opener thing on air cleaner.
Old Jan 21, 2003 | 07:01 PM
I have a open element air cleaner....
Old Jan 21, 2003 | 07:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like a vacuum line....
We can all tell you and you can insist you didn't take any off as long as you want, but if you don't go look at your vacuum lines, it'll just keep on being that way.
Old Jan 21, 2003 | 08:39 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
Do you have a TBI? Sometimes when I take the air cleaner off my car, those white (i think white) connectors for the injectors will get knocked loose. Make sure they are pushed on tight.
Old Jan 21, 2003 | 09:32 PM
I just checked and everything on the TBI looks to be on tight....
BUT behind the TBI i found a rubber line that was broke, it was behind the TBI, It has a small black plastic piece that had a wire going into the area by the A/C stuff and the rubber line was going towards the TBI, the rubber line continued to the front of the car by the washer fluid and down by the canister in the front?
Is this broken rubber line my problem, or what was the rubber line for??
Old Jan 22, 2003 | 01:28 AM
NTChrist's Avatar
KA-ZAM! Who was right?!? ME!!
and, well, all those other guys that said "vacuum line" too.
That's a vacuum line. It's going to your charcoal canister. Replace the entire line with new hose (available at any parts store in various sizes), as the rest of the line is probably on its way out too.
To be safe, give the rest of the lines a quick inspection. I've found that if one vacuum line goes on me, others are sure to follow. Check for brittleness, cracks, y'know, all the obvious stuff.
Old Jan 22, 2003 | 08:36 AM
Old Jan 24, 2003 | 11:10 PM
I didn't mean to come off as being negative towards your help, it's just that i have no idea when it comes to engines, so i was confused....
Well i replaced the vaccuum line and some other misc lines in the car, and it's running ALOT better now...
Thanks for all the help....
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
