Car seems slow all of a sudden!
Old Jan 22, 2003 | 01:28 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Unless it's just the cold (even though I warm the car up), my car has been getting continuously slower the last month. I used to just punch it and it would really take off, but now it seems sluggish, almost like the clutch is slipping (but I know it isn't!) What might I check? My gauges haven't changed, they still read 190 temp, 60psi oil, 14v alt. HELP!
Old Jan 22, 2003 | 02:23 PM
RJR99SS's Avatar
your cat can possibly be clogged...
Old Jan 22, 2003 | 02:26 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
check the voltage at your TPS sensor. im not sure about TPI engines, but mine is 6 volts at WOT....
Old Jan 22, 2003 | 02:40 PM
Morley's Avatar
One easily overlooked part, PCV valve. When these go it really makes a difference in TPI engines for some reason.
Old Jan 24, 2003 | 07:09 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
more info
Well, I have no cat, so that prob. isn't it but I will check the PCV and the TPS. Does oil get thick in the cold, or would that not matter as long as the car was warm?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
zeitghaist
Aug 18, 2015 07:33 AM
86Base
Aug 8, 2015 01:34 PM
